I want to make a new board working with 115200 (gsm modem) UART.
so I want minimum baud error rate. I look at
https://cache.amobbs.com/bbs_upload782111/files_22/ourdev_508497.html
table and decide to work with ATmega328P 7.3728 Mhz / 3v3
The second step is choosing the right XTAL capacitance (Ce)
Cl = 18 pF (Load Capacitance of External Crystal) [ECS-073-18-20BM-JEN-TR]
Cs = 5 pF (Stray Capacitance; in additional sources says you can take it 2-5 pF)
Ci = 18 pF (ATmega328P datasheet; XTAL/TSOC capacitance)
This formula is given in ATmega datasheet
Ce = 2Cl - Cs - Ci
so
Ce = 2.18 - 5 - 18
External Capacitance is
Ce = 13 pF
CRYSTAL ESR = 70 ohm
is that a true calculation? and true settings for my clock setting?
Fuse Settings :
Low Byte Fuse : 0xFD
High Byte Fuse : 0xDA
Extended Byte Fuse : 0xFD
