Hi friends!
I am making a Self-Balancing Robot. I have got very good results, but I want to improve the code. Recently, I have discovered de possibility to use an auto-tune (Arduino PID Autotune Library), to tune in the constants kp, ki, kd of PID. However, I am using my own PID (that works very well), so I do not want to use the libraries of PID-Arduino.
After to read the description of this library, I think that I only need the Input, output, and noise band (in my case 1º, approximately). I am getting the Input from sensor MPU6050, the output (U) is the signal to control the motors, and using the serial plotter, I think that my noise band is one degree.
I have added the code of my robot. But I can’t find the way to calculate and use automatically the constants kp, ki, kd. Please, can you help me?
Thanks!
#include <PID_AutoTune_v0.h>
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps20.h"
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
#include "Wire.h"
#endif
MPU6050 mpu;
bool blinkState = false;
// MPU control/status vars
bool dmpReady = false; // set true if DMP init was successful
uint8_t mpuIntStatus; // holds actual interrupt status byte from MPU
uint8_t devStatus; // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize; // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount; // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
// orientation/motion vars
Quaternion q; // [w, x, y, z] quaternion container
VectorFloat gravity; // [x, y, z] gravity vector
float ypr[3]; // [yaw, pitch, roll] yaw/pitch/roll container and gravity vector
// packet structure for InvenSense teapot demo
volatile bool mpuInterrupt = false; // indicates whether MPU interrupt pin has gone high
void dmpDataReady() {
mpuInterrupt = true;
int IN1 = 4; //motors
int IN2 = 5; //motors
int ENA = 3; //motors PWM
int IN3 = 8; //motors
int IN4 = 9; //motors
int ENB = 10; //motors PWM
// Variables PID
unsigned long lastTime;
double U, Setpoint = 15.10, Ui, Ud, Up, Input; // U = Output, Input = the angle from kalman filter
double ITerm, lastInput;
double kp, ki, kd;
int SampleTime = 5; //
double outMin = -128, outMax = 128;
double error;
PID_ATune aTune(&Input, &U);
// join I2C bus (I2Cdev library doesn't do this automatically)
Wire.begin();
TWBR = 24; // 400kHz I2C clock (200kHz if CPU is 8MHz)
#elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
Fastwire::setup(400, true);
#endif
mpu.initialize();
devStatus = mpu.dmpInitialize();
// supply your own gyro offsets here, scaled for min sensitivity
mpu.setXGyroOffset(-871);
mpu.setYGyroOffset(-5);
mpu.setZGyroOffset(21);
mpu.setZAccelOffset(1105); // 1688 factory default for my test chip
// make sure it worked (returns 0 if so)
if (devStatus == 0) {
// turn on the DMP, now that it's ready
mpu.setDMPEnabled(true);
// enable Arduino interrupt detection
attachInterrupt(0, dmpDataReady, RISING);
mpuIntStatus = mpu.getIntStatus();
// set our DMP Ready flag so the main loop() function knows it's okay to use it
dmpReady = true;
// get expected DMP packet size for later comparison
packetSize = mpu.dmpGetFIFOPacketSize();
// ERROR!
// 1 = initial memory load failed
// 2 = DMP configuration updates failed
// (if it's going to break, usually the code will be 1)
Serial.print(F("DMP Initialization failed (code "));
Serial.print(devStatus);
Serial.println(F(")"));
pinMode(IN1, OUTPUT); //Electric Motors
pinMode(IN2, OUTPUT); //Electric Motors
pinMode(ENA,OUTPUT); //Electric Motors
pinMode(IN3, OUTPUT); //Electric Motors
pinMode(IN4, OUTPUT); //Electric Motors
pinMode(ENB,OUTPUT); //Electric Motors
pinMode(A0, INPUT); //Electric Motors
pinMode(A1, INPUT); //Electric Motors
pinMode(A2, INPUT); //Electric Motors
// Autotune
aTune.SetNoiseBand(1);
aTune.SetOutputStep(50);
aTune.SetLookbackSec(20);
aTune.Runtime();
Compute();
void Compute(){
if (!dmpReady) return;
while (!mpuInterrupt && fifoCount < packetSize) {
// reset interrupt flag and get INT_STATUS byte
// get current FIFO count
fifoCount = mpu.getFIFOCount();
// check for overflow (this should never happen unless our code is too inefficient)
if ((mpuIntStatus & 0x10) || fifoCount == 1024) {
// reset so we can continue cleanly
mpu.resetFIFO();
Serial.println(F("FIFO overflow!"));
// otherwise, check for DMP data ready interrupt (this should happen frequently)
} else if (mpuIntStatus & 0x02) {
// wait for correct available data length, should be a VERY short wait
while (fifoCount < packetSize) fifoCount = mpu.getFIFOCount();
// read a packet from FIFO
mpu.getFIFOBytes(fifoBuffer, packetSize);
// track FIFO count here in case there is > 1 packet available
// (this lets us immediately read more without waiting for an interrupt)
fifoCount -= packetSize;
//display Euler angles in degrees
mpu.dmpGetQuaternion(&q, fifoBuffer);
mpu.dmpGetGravity(&gravity, &q);
mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
kp = aTune.GetKp();
ki = aTune.GetKi();
kd = aTune.GetKd();
unsigned long now = millis(); //Current time. Indicates the time lapsed since the program began to execute the program.
int timeChange = (now - lastTime); // It will indicate the time elapsed since the last time the PID was executed
if (timeChange >= SampleTime){ // It is use to know when to execute the PID or tetornar of the function.
Input = ypr[2] * 180/M_PI;
error = Setpoint - Input; //error
ITerm += (ki*error); // Integral del area
if (ITerm> outMax) ITerm= outMax;
else if (ITerm< outMin) ITerm= outMin;
double dInput = (Input - lastInput);
Up = kp*error; //proporcional signal
Ui = ITerm; // integral signal
Ud = kd*dInput; // derivative signal
U = Up + Ui - Ud; // output signal
if (U > outMax) U = outMax;
else if (U < outMin) U = outMin;
lastInput=Input; //time update
lastTime = now; //error update
// motors
if (U <= 0){
digitalWrite(IN1, LOW);
digitalWrite(IN2, HIGH);
analogWrite(ENA, -U);
digitalWrite(IN3, LOW);
digitalWrite(IN4, HIGH);
analogWrite(ENB, -U);
if (U > 0){
digitalWrite(IN1, HIGH);
digitalWrite(IN2,LOW);
analogWrite(ENA, U);
digitalWrite(IN3, HIGH);
digitalWrite(IN4, LOW);
analogWrite(ENB, U);
void SetTunings(double Kp,double Ki,double Kd){
double SampleTimeInSec = ((double)SampleTime)/1000;
kp = Kp;
ki = Ki * SampleTimeInSec;
kd = Kd / SampleTimeInSec;
void SetSampleTime(int NewSampleTime)
if (NewSampleTime > 0){
/* if the user decides to change the sampling time during operation, Ki and Kd will have to adjust to reflect this change. */
double ratio = (double)NewSampleTime / (double)SampleTime;
ki *= ratio;
kd /= ratio;
SampleTime = (unsigned long)NewSampleTime;
void SetOutputLimits(double Min, double Max)
if (Min > Max) return;
outMin = Min;
outMax = Max;
void motores(){
