I am building a self balancing robot and I finally made it to balance but the only problem I am running into is the robot keeps moving. It does not stop.
Here are the parts I am using.
MPU6050
30:1 Metal Gearmotor 37Dx68L mm 12V with 64 CPR Encoder (Helical Pinion)
I have connected the MPU such that when the robot is standing vertically:
+X is up
-X is down
+Y is left
-Y is right
+Z is forward
-Z is backward
The "input angle" that I refer to here after is the angle the robot makes with the +X axis. It is the tilt angle.
I am using cascade controllers where the inner controller controls the tilt angle and the outer controller controls the speed of the robot.
For the outer controller, the desired speed is 0 and the input speed is measured from the encoder, and the output of the outer controller will be the desired angle for the inner angle controller.
As for the inner angle controller, the desired angle comes from the output of the outer speed controller, the input angle comes from MPU6050, and the output of the inner angle controller is used to run the motors.
I have a strong feeling that the robot never stops because of an error that I have in the way I calculate the input angle. Here is the function which takes one parameter "firstTime". In the "setup" function I call calculateInputAngle(true). This will allow me to read the input angle (tilt angle) from accelerometer before running the motors.
The accelerometer gives good result when there is no vibration. Once I start the motors, I call calculateInputAngle(false) so that I get the change in angle from the gyroscope which does not get affected by the vibrations of the motors.
Here is my calculateInputAngle function that I suspect my error is coming from. Does anyone see any problem with it?
void calculateInputAngle(bool firstTime) {
// Read the raw ACC/GYRO data from MPU-6050
readIMUData();
// Subtract the offset calibration value
gyroRaw.x -= calGyroX;
gyroRaw.y -= calGyroY;
gyroRaw.z -= calGyroZ;
accRaw.x -= calAccX;
accRaw.y -= calAccY;
accRaw.z -= calAccZ;
// Convert to instantaneous degrees per second
gyro.z = (double)gyroRaw.z / (double)gyroScaleFactor;
gyro.y = (double)gyroRaw.y / (double)gyroScaleFactor;
acc.x = (double)accRaw.x / (double)accScaleFactor;
acc.z = (double)accRaw.z / (double)accScaleFactor;
accAngleX = atan2(acc.z, acc.x) * RAD_TO_DEG;
if (firstTime) {
inputAngle = accAngleX;
return;
// Complementary filter
// Too much vibration in the systeem makes the acc reading unreliable.
// gyro is less sensetive to vibrations.
// gyro drift a little over time.
// acc term is added to compensate for the drift
inputAngle = a * (inputAngle + gyro.y * dT) + (1 - a) * accAngleX;
Me2. You don't take into account the x acceleration forced by the motors. Your calculation is correct only if the robot is standing still or moving at constant speed. As soon as you start controlling the motors the angle is incorrect.
Thanks for your help. Can you please elaborate on how I should take into account the x acceleration forced by motor. I thought I am already doing this like this:
Shouldn’t this be the angle made by the vertical x-axis?
I have built a self balancing robot and I am running into the same. problem. The robot can stand without any problem but it can't stop. It moves either forward or backward. Tuning the PID for the angle was not difficult. I only needed a value of kp more than 10. Kd was not. doing much. Kd of 2 was able to reduce bouncing. The speed PID did not seem to add any value.
I have placed the IMU vertically and horizontally but there was no difference. The robot keeps moving. I feel that the center of gravity is not on top of the access of rotation. Could that be the problem?
Could someone out there share his / her knowledge.
Thanks
Looks like the MPU-6050 the data rate can be programmed from 4Hz to 8000Hz and the filter response can be from 5Hz to 256Hz. These rates should be considerably faster than the speed PID and angle PID computation rates or oscillation (hunting) will occur.
PJRC dot com sells Arduino-compatible ARM-duinos with high clock rates (Teensy 4.1 is 600MHz) and Floating Point Units in the 32-bit cores. Floating point calculations without FPU except for powers of 10 operations magnitudes slower than using integers.
