Self balancing robot- motors not spinning and no bluetooth control
Hello, first of all, I hope I'm posting in the right category.
I'm trying to make a self-balancing robot controlled by Bluetooth. I'm following an already made project but I'm having problems with mine. I can't drive my motors which are controlled by the L298N motor driver and my Bluetooth module(HC-05) can't connect to an app on my phone.
The project which I'm following:
Hardware that I'm using:
Arduino Uno
6xAA 1.5V batteries
L298N Motor driver
MPU6050 accelerometer and gyroscope
2 DC motors
Breadboard
The Code:
#include "I2Cdev.h"
#include<Wire.h>
#include <PID_v1.h>
#include "MPU6050_6Axis_MotionApps20.h"
#include<SoftwareSerial.h>
#include <digitalIOPerformance.h>                //library for faster pin R/W
//#include <Ultrasonic.h>
#define d_speed 1.5
#define d_dir 3
#define IN1 11
#define IN2 10
#define IN3 9
#define IN4 3
char content = 'P';
int MotorAspeed, MotorBspeed;
float MOTORSLACK_A = 40;                   // Compensate for motor slack range (low PWM values which result in no motor engagement)
float MOTORSLACK_B = 40;
#define BALANCE_PID_MIN -255              // Define PID limits to match PWM max in reverse and foward
#define BALANCE_PID_MAX 255
MPU6050 mpu;
const int rxpin = 6;       //Bluetooth serial stuff
const int txpin = 5;
SoftwareSerial blue(rxpin, txpin);
//Ultrasonic ultrasonic(A0, A1);
//int distance;
// MPU control/status vars
bool dmpReady = false;  // set true if DMP init was successful
uint8_t mpuIntStatus;   // holds actual interrupt status byte from MPU
uint8_t devStatus;      // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize;    // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount;     // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
// orientation/motion vars
Quaternion q;           // [w, x, y, z]         quaternion container
VectorFloat gravity;    // [x, y, z]            gravity vector
float ypr[3];           // [yaw, pitch, roll]   yaw/pitch/roll container and gravity vector
/*********Tune these 4 values for your BOT*********/
double setpoint; //set the value when the bot is perpendicular to ground using serial monitor.
double originalSetpoint;
//Read the project documentation on circuitdigest.com to learn how to set these values
#define Kp  10 //Set this first
#define Kd  0.6 //Set this secound
#define Ki  160 //Finally set this
#define RKp  50 //Set this first
#define RKd 4//Set this secound
#define RKi  300 //Finally set this
/******End of values setting*********/
double ysetpoint;
double yoriginalSetpoint;
double input, yinput, youtput, output, Buffer[3];
PID pid(&input, &output, &setpoint, Kp, Ki, Kd, DIRECT);
PID rot(&yinput, &youtput, &ysetpoint, RKp, RKi, RKd, DIRECT);
volatile bool mpuInterrupt = false;     // indicates whether MPU interrupt pin has gone high
void dmpDataReady()
  mpuInterrupt = true;
  blue.begin(9600);
  blue.setTimeout(10);
  init_imu();           //initialiser le MPU6050
  initmot();            //initialiser les moteurs
  originalSetpoint = 176;  //consigne
  yoriginalSetpoint = 0.1;
  setpoint = originalSetpoint ;
  ysetpoint = yoriginalSetpoint ;
    getvalues();
    Bt_control();
    printval();
void init_imu() {
  // initialize device
  Serial.println(F("Initializing I2C devices..."));
  Wire.begin();
  TWBR = 24;
  mpu.initialize();
  // verify connection
  Serial.println(F("Testing device connections..."));
  Serial.println(mpu.testConnection() ? F("MPU6050 connection successful") : F("MPU6050 connection failed"));
  // load and configure the DMP
  devStatus = mpu.dmpInitialize();
  // supply your own gyro offsets here, scaled for min sensitivity
  mpu.setXGyroOffset(220);
  mpu.setYGyroOffset(76);
  mpu.setZGyroOffset(-85);
  mpu.setZAccelOffset(1688);
  // make sure it worked (returns 0 if so)
  if (devStatus == 0) {
    // turn on the DMP, now that it's ready
    Serial.println(F("Enabling DMP..."));
    mpu.setDMPEnabled(true);
    // enable Arduino interrupt detection
    Serial.println(F("Enabling interrupt detection (Arduino external interrupt 0)..."));
    attachInterrupt(0, dmpDataReady, RISING);
    mpuIntStatus = mpu.getIntStatus();
    // set our DMP Ready flag so the main loop() function knows it's okay to use it
    Serial.println(F("DMP ready! Waiting for first interrupt..."));
    dmpReady = true;
    // get expected DMP packet size for later comparison
    packetSize = mpu.dmpGetFIFOPacketSize();
    //setup PID
    pid.SetMode(AUTOMATIC);
    pid.SetSampleTime(10);
    pid.SetOutputLimits(-255, 255);
    rot.SetMode(AUTOMATIC);
    rot.SetSampleTime(10);
    rot.SetOutputLimits(-20, 20);
    // ERROR!
    // 1 = initial memory load failed
    // 2 = DMP configuration updates failed
    // (if it's going to break, usually the code will be 1)
    Serial.print(F("DMP Initialization failed (code "));
    Serial.print(devStatus);
    Serial.println(F(")"));
void getvalues() {
  // if programming failed, don't try to do anything
  if (!dmpReady) return;
  // wait for MPU interrupt or extra packet(s) available
  while (!mpuInterrupt && fifoCount < packetSize) {
    new_pid();
  // reset interrupt flag and get INT_STATUS byte
  // get current FIFO count
  fifoCount = mpu.getFIFOCount();
  // check for overflow (this should never happen unless our code is too inefficient)
  if ((mpuIntStatus & 0x10) || fifoCount == 1024)
    // reset so we can continue cleanly
    mpu.resetFIFO();
    Serial.println(F("FIFO overflow!"));
    // otherwise, check for DMP data ready interrupt (this should happen frequently)
  else if (mpuIntStatus & 0x02)
    // wait for correct available data length, should be a VERY short wait
    while (fifoCount < packetSize) fifoCount = mpu.getFIFOCount();
    // read a packet from FIFO
    mpu.getFIFOBytes(fifoBuffer, packetSize);
    // track FIFO count here in case there is > 1 packet available
    // (this lets us immediately read more without waiting for an interrupt)
    fifoCount -= packetSize;
    mpu.dmpGetQuaternion(&q, fifoBuffer); //get value for q
    mpu.dmpGetGravity(&gravity, &q); //get value for gravity
    mpu.dmpGetYawPitchRoll(ypr, &q, &gravity); //get value for ypr
    input = ypr[1] * 180 / M_PI + 180;
    yinput = ypr[0] * 180 / M_PI;
void new_pid() {
  //Compute error
  pid.Compute();
  rot.Compute();
  // Convert PID output to motor control
  MotorAspeed = compensate_slack(youtput, output, 1);
  MotorBspeed = compensate_slack(youtput, output, 0);
  motorspeed(MotorAspeed, MotorBspeed);            //change speed
//Fast digitalWrite is implemented
void Bt_control() {
  if (blue.available()) {
    content = blue.read();
    if (content == 'F')
      setpoint = originalSetpoint - d_speed;//Serial.println(setpoint);}            //forward
    else if (content == 'B')
      setpoint = originalSetpoint + d_speed;//Serial.println(setpoint);}            //backward
    else if (content == 'L')
      ysetpoint = constrain((ysetpoint + yoriginalSetpoint - d_dir), -180, 180); //Serial.println(ysetpoint);}      //left
    else if (content == 'R')
      ysetpoint = constrain(ysetpoint + yoriginalSetpoint + d_dir, -180, 180); //Serial.println(ysetpoint);}        //right
    else if (content == 'S') {
      setpoint = originalSetpoint;
  else content = 'P';
void initmot() {
  //Initialise the Motor outpu pins
  pinMode (IN4, OUTPUT);
  pinMode (IN3, OUTPUT);
  pinMode (IN2, OUTPUT);
  pinMode (IN1, OUTPUT);
  //By default turn off both the motor
  analogWrite(IN4, LOW);
  analogWrite(IN3, LOW);
  analogWrite(IN2, LOW);
  analogWrite(IN1, LOW);
double compensate_slack(double yOutput, double Output, bool A) {
  // Compensate for DC motor non-linear "dead" zone around 0 where small values don't result in movement
  //yOutput is for left,right control
  if (A)
    if (Output >= 0)
      Output = Output + MOTORSLACK_A - yOutput;
    if (Output < 0)
      Output = Output - MOTORSLACK_A - yOutput;
    if (Output >= 0)
      Output = Output + MOTORSLACK_B + yOutput;
    if (Output < 0)
      Output = Output - MOTORSLACK_B + yOutput;
  Output = constrain(Output, BALANCE_PID_MIN, BALANCE_PID_MAX);
  return Output;
void motorspeed(int MotorAspeed, int MotorBspeed) {
  // Motor A control
  if (MotorAspeed >= 0) {
    analogWrite(IN1, abs(MotorAspeed));
    digitalWrite(IN2, LOW);
  else {
    digitalWrite(IN1, LOW);
    analogWrite(IN2, abs(MotorAspeed));
  // Motor B control
  if (MotorBspeed >= 0) {
    analogWrite(IN3, abs(MotorBspeed));
    digitalWrite(IN4, LOW);
  else {
    digitalWrite(IN3, LOW);
    analogWrite(IN4, abs(MotorBspeed));
void printval()
  Serial.print(yinput); Serial.print("\t");
  Serial.print(yoriginalSetpoint); Serial.print("\t");
  Serial.print(ysetpoint); Serial.print("\t");
  Serial.print(youtput); Serial.print("\t"); Serial.print("\t");
  Serial.print(input); Serial.print("\t");
  Serial.print(originalSetpoint); Serial.print("\t");
  Serial.print(setpoint); Serial.print("\t");
  Serial.print(output); Serial.print("\t"); Serial.print("\t");
  Serial.print(MotorAspeed); Serial.print("\t");
  Serial.print(MotorBspeed); Serial.print("\t"); Serial.print(content); Serial.println("\t");
Schematics:
Is something wrong with my wiring? I'm stuck and don't know what's the next step.
Any help is appreciated. Thank you!
Is there an 'enable' pin on your motor driver that is supposed to be set HIGH or LOW to enable the driver?
The HC-05 module Vcc needs to be connected to 5v not 3.3.
The phone app connects to the module. First you need to pair the phone with the module.
I strongly recommend that you use a well vetted blutetooth terminal app like Kai Morich's Serial Bluetooth Terminal
before using any thing from the instructable.
I have no idea why you thought that this is an Avrdude, stk500 or Bootloader issue, Your topic has been moved to a more suitable location on the forum.
Dear sir
I am the begginer and need your help i have same issue kindly suggest me what is the enable pin in motor shield and how to operate this.
Thanking you.
