Self Balancing Robot project- wheels only spin in one direction
Hello everyone,
I have finished building the circuit for my self balancing robot, yet it is not working as intended. After connecting the power source, the dc motor wheels spin at a constant speed and only in one direction, regardless of how the MPU6050 is tilted. My serial monitor has also been reading gibberish letters and symbols when I have the circuit connected. I believe I have added the PID libraries correct to the Arduino library, as the sketch successfully downloaded to my arduino, but I am not 100% sure. Any help that can be offered would be greatly appreciated. I have posted a link where the code project details, and the circuit diagram can be seen. DIY Self Balancing Robot using Arduino
Hi, @cmantheballer
Welcome to the forum.
Please read the post at the start of any forum , entitled "How to use this Forum".
Can you please post your code?
Do you have the IDE serial monitor at the correct baud rate?
Can you please tell us your electronics, programming, arduino, hardware experience?
Thanks.. Tom... :grinning: :+1: :coffee: :australia:
Sounds like a wiring error. Check every wire.
You need to write some code of your own to test the motor drive hardware.
Can you please post the self balancing code that you are using now?
To add code please click this link;
Yes, I doubled checked to ensure I was set to the correct baud rate but still was receiving these symbols. I believe the issue stems at the arduino/code, as when i detach the power only supplying the arduino, the wheels do not spin at all. I have built many arduino projects in the past but this would be my biggest project so far. My main limitation comes with troubleshooting code. I have posted the mentioned code below:
/*Arduino Self Balancing Robot
#include "I2Cdev.h"
#include <PID_v1.h>
#include "MPU6050_6Axis_MotionApps20.h"
MPU6050 mpu;
// MPU control/status vars
bool dmpReady = false; // set true if DMP init was successful
uint8_t mpuIntStatus; // holds actual interrupt status byte from MPU
uint8_t devStatus; // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize; // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount; // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
// orientation/motion vars
Quaternion q; // [w, x, y, z] quaternion container
VectorFloat gravity; // [x, y, z] gravity vector
float ypr[3]; // [yaw, pitch, roll] yaw/pitch/roll container and gravity vector
/Tune these 4 values for your BOT/
double setpoint= 176; //set the value when the bot is perpendicular to ground using serial monitor.
//Read the project documentation on circuitdigest.com to learn how to set these values
double Kp = 21; //Set this first
double Kd = 0.8; //Set this secound
double Ki = 140; //Finally set this
/End of values setting***/
double input, output;
PID pid(&input, &output, &setpoint, Kp, Ki, Kd, DIRECT);
volatile bool mpuInterrupt = false; // indicates whether MPU interrupt pin has gone high
void dmpDataReady()
mpuInterrupt = true;
// initialize device
Serial.println(F("Initializing I2C devices..."));
mpu.initialize();
 // verify connection
Serial.println(F("Testing device connections..."));
Serial.println(mpu.testConnection() ? F("MPU6050 connection successful") : F("MPU6050 connection failed"));
// load and configure the DMP
devStatus = mpu.dmpInitialize();
// supply your own gyro offsets here, scaled for min sensitivity
mpu.setXGyroOffset(220);
mpu.setYGyroOffset(76);
mpu.setZGyroOffset(-85);
mpu.setZAccelOffset(1688);
  // make sure it worked (returns 0 if so)
if (devStatus == 0)
    // turn on the DMP, now that it's ready
    Serial.println(F("Enabling DMP..."));
    mpu.setDMPEnabled(true);
    // enable Arduino interrupt detection
    Serial.println(F("Enabling interrupt detection (Arduino external interrupt 0)..."));
    attachInterrupt(0, dmpDataReady, RISING);
    mpuIntStatus = mpu.getIntStatus();
    // set our DMP Ready flag so the main loop() function knows it's okay to use it
    Serial.println(F("DMP ready! Waiting for first interrupt..."));
    dmpReady = true;
    // get expected DMP packet size for later comparison
    packetSize = mpu.dmpGetFIFOPacketSize();
    //setup PID
    pid.SetMode(AUTOMATIC);
    pid.SetSampleTime(10);
    pid.SetOutputLimits(-255, 255);
    // ERROR!
    // 1 = initial memory load failed
    // 2 = DMP configuration updates failed
    // (if it's going to break, usually the code will be 1)
    Serial.print(F("DMP Initialization failed (code "));
    Serial.print(devStatus);
    Serial.println(F(")"));
//Initialise the Motor outpu pins
pinMode (6, OUTPUT);
pinMode (9, OUTPUT);
pinMode (10, OUTPUT);
pinMode (11, OUTPUT);
//By default turn off both the motors
analogWrite(6,LOW);
analogWrite(9,LOW);
analogWrite(10,LOW);
analogWrite(11,LOW);
// if programming failed, don't try to do anything
if (!dmpReady) return;
// wait for MPU interrupt or extra packet(s) available
while (!mpuInterrupt && fifoCount < packetSize)
    //no mpu data - performing PID calculations and output to motors
    pid.Compute();
    //Print the value of Input and Output on serial monitor to check how it is working.
    Serial.print(input); Serial.print(" =>"); Serial.println(output);
    if (input>150 && input<200){//If the Bot is falling
    if (output>0) //Falling towards front
    Forward(); //Rotate the wheels forward
    else if (output<0) //Falling towards back
    Reverse(); //Rotate the wheels backward
    else //If Bot not falling
    Stop(); //Hold the wheels still
// reset interrupt flag and get INT_STATUS byte
// get current FIFO count
fifoCount = mpu.getFIFOCount();
// check for overflow (this should never happen unless our code is too inefficient)
if ((mpuIntStatus & 0x10) || fifoCount == 1024)
    // reset so we can continue cleanly
    mpu.resetFIFO();
    Serial.println(F("FIFO overflow!"));
// otherwise, check for DMP data ready interrupt (this should happen frequently)
else if (mpuIntStatus & 0x02)
    // wait for correct available data length, should be a VERY short wait
    while (fifoCount < packetSize) fifoCount = mpu.getFIFOCount();
    // read a packet from FIFO
    mpu.getFIFOBytes(fifoBuffer, packetSize);
    // track FIFO count here in case there is > 1 packet available
    // (this lets us immediately read more without waiting for an interrupt)
    fifoCount -= packetSize;
    mpu.dmpGetQuaternion(&q, fifoBuffer); //get value for q
    mpu.dmpGetGravity(&gravity, &q); //get value for gravity
    mpu.dmpGetYawPitchRoll(ypr, &q, &gravity); //get value for ypr
    input = ypr[1] * 180/M_PI + 180;
void Forward() //Code to rotate the wheel forward
analogWrite(6,output);
analogWrite(9,0);
analogWrite(10,output);
analogWrite(11,0);
Serial.print("F"); //Debugging information
void Reverse() //Code to rotate the wheel Backward
analogWrite(6,0);
analogWrite(9,output*-1);
analogWrite(10,0);
analogWrite(11,output*-1);
Serial.print("R");
void Stop() //Code to stop both the wheels
analogWrite(6,0);
analogWrite(9,0);
analogWrite(10,0);
analogWrite(11,0);
Serial.print("S");
This is a course project due on Wednesday, so any help that can readily offered would be appreciated. Thank you.
Please read the instructions posted in post #4 on how to post your code.
 * Code by: B.Aswinth Raj
 * Build on top of Lib: https://github.com/jrowberg/i2cdevlib/tree/master/Arduino/MPU6050
 * Website: circuitdigest.com
#include "I2Cdev.h"
#include <PID_v1.h> //From https://github.com/br3ttb/Arduino-PID-Library/blob/master/PID_v1.h
#include "MPU6050_6Axis_MotionApps20.h" //https://github.com/jrowberg/i2cdevlib/tree/master/Arduino/MPU6050
MPU6050 mpu;
/*********Tune these 4 values for your BOT*********/
/******End of values setting*********/
void dmpDataReady()
    mpu.initialize();
    if (devStatus == 0)
        dmpReady = true;
        //setup PID
        // ERROR!
    analogWrite(6,LOW);
    analogWrite(9,LOW);
        pid.Compute();
        mpu.resetFIFO();
    analogWrite(9,0);
    analogWrite(11,0);
    analogWrite(6,0);
    analogWrite(10,0);
    Serial.print("R");
    analogWrite(6,0);
    analogWrite(9,0);
    analogWrite(10,0);
    analogWrite(11,0);
    Serial.print("S");
I have checked the wiring for my project to ensure there were no faulty connections, yet the wheels still spin at a constant rate in one direction.
Unfortunately I have checked this issue to no prevail :frowning:
Here is also a picture of the output I am receiving from the serial monitor:
Looks like a baudrate mismatch. Does your sketch have Serial.begin(115200);?
Yes I matched the serial port baudrate with the baudrate mentioned in the code, but still receive the same letters and symbols.
One thing I can suggest is to initialize the motor control pins at the TOP of setup() rather than at the bottom. That way, if the initialization of the MPU6050 gets stuck you will at least have the motors turned off.
If this helps, I have posted the circuit itself for this project along with my physical setup following this procedure. I have checked many times that the connections matched, but still no luck. At this point I believe the issue is arising from either the method of including the PID libraries into arduino library or the arduino code itself.
After attempting this I receive this error:
#include "I2Cdev.h"
MPU6050 mpu;
double setpoint= 1; //set the value when the bot is perpendicular to ground using serial monitor.
void dmpDataReady()
    mpu.initialize();
    if (devStatus == 0)
        dmpReady = true;
        //setup PID
        // ERROR!
    analogWrite(6,LOW);
    analogWrite(9,LOW);
        pid.Compute();
        mpu.resetFIFO();
    analogWrite(9,0);
    analogWrite(11,0);
    analogWrite(6,0);
    analogWrite(10,0);
    Serial.print("R");
    analogWrite(6,0);
    analogWrite(9,0);
    analogWrite(10,0);
    analogWrite(11,0);
    Serial.print("S");
I am not an experienced coder so my high hopes were that this code worked as intended. Others have had success but with little explanantion. Could this issue of one direction rotation be due to the PID libraries not being in the arduino library correctly? If the libraries are not present would the wheels still spin, as no input is being detected from accelerometer? Thanks for the help
Not ABOVE setup().
Okay, I see. I have just successfully downloaded this new sketch to the arduino, yet sadly the same issue is happening of constant speed and direction in the wheels.
In terms of the PID libraries, I uploaded the PID_v1.h to the arduino library but the MPU6050_6Axis_MotionApps20.h would not download to the library, so I copy and pasted this in a new tab under the same sketch (which I believe is correct use of the angle bracket and quote notation for the #include function). Could this potentially be an issue?
Download the entire i2cdevlib: GitHub - jrowberg/i2cdevlib: I2C device library collection for AVR/Arduino or other C++-based MCUs
Then copy 'Arduino/I2Cdev' and 'Arduino/MPU6050' to the libraries folder.
Yes. Have you said you can run the motors backwards and forwards using direct commands in a test program?
a7
