Self-balancing robot with BT module
This code is for a self-balancing autonomous robot. I want to integrate an H Bluetooth module for control via any Bluetooth app, but I'm a beginner and don’t know how. Can someone help me merge it and make it work?
#include "PID_v1.h"
#include "LMotorController.h"
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps20.h"
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
    #include "Wire.h"
#endif
#define MIN_ABS_SPEED 20
MPU6050 mpu;
// MPU control/status vars
bool dmpReady = false;  // set true if DMP init was successful
uint8_t mpuIntStatus;   // holds actual interrupt status byte from MPU
uint8_t devStatus;      // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize;    // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount;     // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
// orientation/motion vars
Quaternion q;           // [w, x, y, z]         quaternion container
VectorFloat gravity;    // [x, y, z]            gravity vector
float ypr[3];           // [yaw, pitch, roll]   yaw/pitch/roll container and gravity vector
//PID
double originalSetpoint = 183;
double setpoint = originalSetpoint;
double movingAngleOffset = 0.1;
double input, output;
int moveState=0; //0 = balance; 1 = back; 2 = forth
double Kp = 37; // First adjustment
double Kd = 2.7; // Second adjustment
double Ki = 330; // Third adjustment
PID pid(&input, &output, &setpoint, Kp, Ki, Kd, DIRECT); // kp = 55,kd=0.9
double motorSpeedFactorLeft = 0.6;
double motorSpeedFactorRight = 0.6;
//MOTOR CONTROLLER
int ENA = 5;
int IN1 = 6;
int IN2 = 7;
int IN3 = 9;
int IN4 = 8;
int ENB = 10;
LMotorController motorController(ENA, IN1, IN2, ENB, IN3, IN4, motorSpeedFactorLeft, motorSpeedFactorRight);
//timers
long time1Hz = 0;
long time5Hz = 0;
volatile bool mpuInterrupt = false;     // indicates whether MPU interrupt pin has gone high
void dmpDataReady()
    mpuInterrupt = true;
    // join I2C bus (I2Cdev library doesn't do this automatically)
        Wire.begin();
        TWBR = 24; // 400kHz I2C clock (200kHz if CPU is 8MHz)
    #elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
        Fastwire::setup(400, true);
    #endif
    // initialize serial communication
    // (115200 chosen because it is required for Teapot Demo output, but it's
    // really up to you depending on your project)
    while (!Serial); // wait for Leonardo enumeration, others continue immediately
    // initialize device
    Serial.println(F("Initializing I2C devices..."));
    mpu.initialize();
    // verify connection
    Serial.println(F("Testing device connections..."));
    Serial.println(mpu.testConnection() ? F("MPU6050 connection successful") : F("MPU6050 connection failed"));
    // load and configure the DMP
    Serial.println(F("Initializing DMP..."));
    devStatus = mpu.dmpInitialize();
    // supply your own gyro offsets here, scaled for min sensitivity
     mpu.setXGyroOffset(104);
     mpu.setYGyroOffset(75);
     mpu.setZGyroOffset(26);
     mpu.setZAccelOffset(16380);
 // 1688 factory default for my test chip
    // make sure it worked (returns 0 if so)
    if (devStatus == 0)
        // turn on the DMP, now that it's ready
        Serial.println(F("Enabling DMP..."));
        mpu.setDMPEnabled(true);
        // enable Arduino interrupt detection
        Serial.println(F("Enabling interrupt detection (Arduino external interrupt 0)..."));
        attachInterrupt(0, dmpDataReady, RISING);
        mpuIntStatus = mpu.getIntStatus();
        // set our DMP Ready flag so the main loop() function knows it's okay to use it
        Serial.println(F("DMP ready! Waiting for first interrupt..."));
        dmpReady = true;
        // get expected DMP packet size for later comparison
        packetSize = mpu.dmpGetFIFOPacketSize();
        //setup PID
        pid.SetMode(AUTOMATIC);
        pid.SetSampleTime(10);
        pid.SetOutputLimits(-255, 255);
        // ERROR!
        // 1 = initial memory load failed
        // 2 = DMP configuration updates failed
        // (if it's going to break, usually the code will be 1)
        Serial.print(F("DMP Initialization failed (code "));
        Serial.print(devStatus);
        Serial.println(F(")"));
    // if programming failed, don't try to do anything
    if (!dmpReady) return;
    // wait for MPU interrupt or extra packet(s) available
    while (!mpuInterrupt && fifoCount < packetSize)
        //no mpu data - performing PID calculations and output to motors
        pid.Compute();
        motorController.move(output, MIN_ABS_SPEED);
    // reset interrupt flag and get INT_STATUS byte
    // get current FIFO count
    fifoCount = mpu.getFIFOCount();
    // check for overflow (this should never happen unless our code is too inefficient)
    if ((mpuIntStatus & 0x10) || fifoCount == 1024)
        // reset so we can continue cleanly
        mpu.resetFIFO();
        Serial.println(F("FIFO overflow!"));
    // otherwise, check for DMP data ready interrupt (this should happen frequently)
    else if (mpuIntStatus & 0x02)
        // wait for correct available data length, should be a VERY short wait
        while (fifoCount < packetSize) fifoCount = mpu.getFIFOCount();
        // read a packet from FIFO
        mpu.getFIFOBytes(fifoBuffer, packetSize);
        // track FIFO count here in case there is > 1 packet available
        // (this lets us immediately read more without waiting for an interrupt)
        fifoCount -= packetSize;
        mpu.dmpGetQuaternion(&q, fifoBuffer);
        mpu.dmpGetGravity(&gravity, &q);
        mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
        #if LOG_INPUT
            Serial.print("ypr\t");
            Serial.print(ypr[0] * 180/M_PI);
            Serial.print("\t");
            Serial.print(ypr[1] * 180/M_PI);
            Serial.print("\t");
            Serial.println(ypr[2] * 180/M_PI);
        #endif
        input = ypr[1] * 180/M_PI + 180;
}Use code tags to format code for the forum`Use code tags to format code for the forum`
Please, don't write a poem as the topic subject, use just a few words there to focus the question, then use the post body to describe your project and problems in full details.
Also always enclose the code inside the "code" tags to make it readable. Please edit your post above (using the little pencil button :pencil2: at the bottom of your first post), select your code, press the "<CODE/>" icon in the toolbar and save.
Thanks.
Thanks for your help brother, this is my first time here so I don't know
Good, thanks.
If you're a beginner your code looks too complex to be something you made up... What are your current skills (I mean programming and electronics)? Are you trying to extend code made by someone else?
And just to start, what are exactly your requirements (what you plan to do with bluetooth commands?) and what is your experience in mobile programming? And talking about "apps", you mean Androind or Apple?
PS: if you just need to know what you can do to create an app, have a look HERE, MIT Appinventor colud let you create apps with a visual approach.
I am a beginner. I know the basics, but I took this code ready-made from the internet. I just wanted to connect the HC05 Bluetooth module so I can control it using any Android app that controls the robot. That's what I wanted
I understand, but I'm afraid it isn't a simple task for a beginner to add such kind of functionality to a program you know nothing about.
And, sorry to say, I hope you aren't expectig us to do that for you, we do not program for third parties: if you already know Arduino basics, you need to do your job first, and that's the best way if you want to learn more and be able to make your own code. You could create some test sketches to put your hands on bluetooth communication (but remember you need also to use or create an app to do that, AppInventor could be a good start) or search the net for some Arduino-BT communication examples, and we could give you some advice on this first relatively simple task, just start and see what you'll get.
Once you've had a minimal level of practice about that, start adding your code to that third party sketch, and if you're in trouble you can obviously post here your modified code together with a description of what goes wrong and we'll be happy to try and help you in improving it.
Or ask the author of that code if he/she could add such functionality for you. :wink:
