Self-balancing robot
Hello!
I am looking to hire someone to assist/consult me in a robotics project - paid freelance gig of course.
The project is very similar to this project --> Get on the Tightrope | Tightrope Unicycle Bot | Adafruit Learning System , with some particular tweaks.
I have seen some other similar robotic projects that utilize a gyroscope above the tightrope. Not sure which solution would be the most reliable for my case.
Below is the final vision.
A robot that can self-balance and travel back and forth along a 20ft tightrope or thin track. This is for an exhibition I am putting together in February, and I will be fabricating a lightweight carcass to put around the robot in form of a man carrying two barbells like this --> https://i.ebayimg.com/images/g/26gAAOSwLClk-0Wk/s-l1600.jpg
I am located in Oakland, CA, but very open to working remote with a little guidance.
If you are interested, please respond or email me at info@field.productions.
Thank you!
If you are attempting to produce an inverted pendulum application, see: 00964A.pdf (microchip.com).
