Hey guys. I have made a self balancing robot now. The problem is:
When connected with the battery and made to run, runs for a few seconds and the input from the
MPU6050 gets random. I suspect this is because of the vibration of the motor causing the wires to connect
and disconnect, because if i connect to the computer it runs properly.
Can anyone identify the problem
my code if necessary, i thing the problem might be in the hardware
#include <Wire.h>
const int MPU_addr=0x68;
int16_t AcX,AcY,AcZ,Tmp,GyX,GyY,GyZ;
int minVal=265; int maxVal=402;
double x; //A4 (SDA), A5 (SCL)
double y;
double z;
int lmt1=6;
int lmt2=5;
int rmt1=9;
int rmt2=10;
int value;
void setup(){
pinMode(lmt1,OUTPUT);
pinMode(lmt2,OUTPUT);
pinMode(rmt1,OUTPUT);
pinMode(rmt2,OUTPUT);
Wire.begin();
Wire.beginTransmission(MPU_addr);
Wire.write(0x6B); Wire.write(0);
Wire.endTransmission(true);
Serial.begin(9600); }
void loop(){
Wire.write(0x3B);
Wire.endTransmission(false);
Wire.requestFrom(MPU_addr,14,true);
AcX=Wire.read()<<8|Wire.read();
AcY=Wire.read()<<8|Wire.read();
AcZ=Wire.read()<<8|Wire.read();
int xAng = map(AcX,minVal,maxVal,-90,90);
int yAng = map(AcY,minVal,maxVal,-90,90);
int zAng = map(AcZ,minVal,maxVal,-90,90);
x= RAD_TO_DEG * (atan2(-yAng, -zAng)+PI);
y= RAD_TO_DEG * (atan2(-xAng, -zAng)+PI);
z= RAD_TO_DEG * (atan2(-yAng, -xAng)+PI);
//---------------------------------------------- This part of the program is
// just to convert the angle from the gyro (0-360)
// into -180 to 180
if(y>180){
y=y-360;
if(y<180){
//--------------------------------------------- back tilt response
if(y>0)//backward tilt +
value=map(y,0,45,50,255);
analogWrite(lmt1,value);
analogWrite(lmt2,0);
analogWrite(rmt1,value);
analogWrite(rmt2,0);
Serial.print("b ");
//---------------------------------------------- front tilt response
if(y<0)//forward tilt -
y=y*-1;
analogWrite(lmt1,0);
analogWrite(lmt2,value);
analogWrite(rmt1,0);
analogWrite(rmt2,value);
Serial.print(y);
Serial.print(" ");
Serial.println(value);
and i understand i should be using PID algorithm to balance the robot but for now this
