Self-Etched Purpose-Built Duemilanove Clone
Some of you guys probably saw my help thread in the troubleshooting section. I decided to scrap that board, after finding a lot of hairline breaks in some traces, and because I wanted to add a power jack and remove the ICSP header. So I present v2 of my small Duemilanove clone. Its going to be used to measure temperature, humidity, etc in a room, switch a light on and off at set intervals, and display stuff on an LCD. The board also has a Dallas DS1307 RTC onboard, along with a coin-cell battery, and a DS13kHz temperature-corrected oscillator.
Enjoy the pictures:
what transfer method did you use?
I printed the Eagle design on a clear overhead, and used photoboard and a developer.
What are the two metal "boxes" on the board? One is the usb connector I presume, but the other...?
I don't know, but one of them appears to have "LCD" printed next to it.
Well, since the OP isn't replying - they look like RJ45 jacks (the kind of plug that ethernet uses) that are used to connect the external parts of the circuit - like the LCD as TchnclFl suggests.
Heeeyyyy, that RJ45 idea is badass, especially for a simple LCD connector, instead of using bulky IDE cables or something similar, and who doesn't have like 9000 feet of old network cables laying around anyways! lol :slight_smile:
They are both RJ45 ports; one is for the LCD, the other is for the "breakout" board. This way, I can easily disconnect the cables and never worry about reversing a lead! Not to mention Ive got tons of network cable lying around.
Thanks! Glad you like it!
Sorry for not replying earlier, I took a little hiatus and didnt check this thread. I really need to turn on email notifications or something!
