I am trying to slow down the servos in the attached sketch. Can someone please tell me how to change the sketch.
Thanks,
Wally.
#define Version "Semaphore 2.4 2021/08/02 14:30"
// -- documentation re LoopDly
// -- documentation re BounceArc set to 0
// "Semaphore 2.2 2021/05/02 12:00"
// -- Add Bounce
// "Semaphore 2.1 2021/04/18 22:00"
// Controls Dual Semaphore Controller board from MRCS
// Color Resist analog button digital index
// Red2 R1 A0 S4 D4 3
// Yel2 R2 A1 S5 D3 4
// Grn2 R3 A2 S6 D2 5
// Red1 R4 A3 S1 D7 0
// Yel1 R5 A6 S2 D6 1
// Grn1 R6 A7 S3 D5 2
#include <Servo.h>
// How many signals/servos to process?
#define NumSigs 2
// FullArc - the maximum degrees of arc to travel
#define FullArc 60
// Chg 2.2 vvvvvvvvvvvvv
// BounceArc - factor for arc of bounce
// - (green-red)/BounceArc
// - 0 means no bounce
#define BounceArc 0
// BounceDly - delay between moves
#define BounceDly 300
// Chg 2.2 ^^^^^^^^^^^^
// MinPotChg - the minimum ohm change we will act on
#define MinPotChg 10
// HoldMS - time before looking for a new signal
#define HoldMS 1000
// latch = true - hold last active button
#define Latch false
// mirror = true - upper goes counter-clockwise, lower goes clockwise
#define Mirror true
// main loop delay - sample rate
#define LoopDly 1000
// debugging
#define Trace 0
// if debugging, make the LoopDly large
// note ordering: 1R 1Y 1G 2R 2Y 2G
int const PotPins[6] = {A3,A6,A7,A0,A1,A2};
int const ButPins[6] = { 7, 6, 5, 4, 3, 2};
#define RED 0
#define YEL 1
#define GRN 2
int const LEDs [2] = {9,10};// note: high = off
// servos and pins
Servo SemiP[2];
int const ServPins[2] = {12,11};
int ServState [2]; // red/yellow/green
int Posn [2]; // pot position
long int PosnTM [2]; // last position time change
void LEDlert(int Patrn, int Repet) {
// specific for the Dual Semaphore Controller
// Patrn
// 0 = slow blink - active
// 1 = rapid blink - working
// 2 = fast blink - problem
int TurnOn = LOW;
int TurnOff = HIGH;
int ii,jj, Iner;
Iner = (3-Patrn)*100;
for (jj = 0; jj < Repet; ++jj){
for (ii = 0; ii < Patrn+1; ++ii){
digitalWrite(LEDs[0], TurnOn);
delay(Iner);
digitalWrite(LEDs[1], TurnOn);
digitalWrite(LEDs[0], TurnOff);
delay(Iner);
digitalWrite(LEDs[1], TurnOff);
if (jj != Repet-1){delay(Iner);}
}// for ii
if (jj != Repet-1){delay(Iner*5);}
}// for jj
}// LEDlert
void BounceRed(int Iset, int Redval) {
int Ioff, nxtpos, Grnval;
// return to Red causes bounce
#if (BounceArc > 0)
Ioff = Iset * 3;
Grnval = analogRead(PotPins[Ioff+GRN]);
if (Ioff == 0 && Mirror){Grnval = 1023 - Grnval;}
Grnval = map(Grnval, 0, 1023, 0, FullArc);
nxtpos = (Grnval - Redval)/BounceArc;
if (Trace > 0){
Serial.print("Bounce G: ");
Serial.print(Grnval);
Serial.print(" R:");
Serial.print(Redval);
Serial.print(" nxt: ");
Serial.println(nxtpos);
}// Trace
do {
if (Trace > 0){
Serial.print("Bounce to ");
Serial.println(Redval + nxtpos);
}// Trace
delay (BounceDly);
SemiP[Iset].write(Redval + nxtpos);
delay (BounceDly);
SemiP[Iset].write(Redval);
nxtpos /= BounceArc;
} while (nxtpos != 0);
#endif
}// BounceRed
long int TuneTM;
int PotPos[6];
// Tuning - time watching for a pot change
#define Tuning 15000
int ii, jj, Cnt, MPin, PotVal;
if (Trace > 0){
Serial.println(Version);
}// Trace
// setup servos and variables
for (ii = 0; ii < 6; ++ii){
pinMode(PotPins[ii], INPUT);
pinMode(ButPins[ii], INPUT_PULLUP);
}// for ii
for (ii = 0; ii < NumSigs; ++ii){
SemiP[ii].attach(ServPins[ii]);
// read red pot & position
Posn[ii] = analogRead(PotPins[ii*3]);
if (ii == 0 && Mirror){Posn[ii] = 1023 - Posn[ii];}
SemiP[ii].write(map(Posn[ii], 0, 1023, 0, FullArc));
PosnTM[ii] = millis();
ServState[ii] = ii * 3;
if (Trace > 0){
Serial.print("Servo ");
Serial.print(ii);
Serial.print(" pot ");
Serial.println(Posn[ii]);
}// for ii
for (ii = 0; ii < 2; ++ii){
pinMode(LEDs[ii], OUTPUT);
digitalWrite(LEDs[ii], HIGH);
}// for ii
if (Trace > 0){// light both for startup
LEDlert(0,1); //
}// Trace
// initialize pot position
for (jj = 0; jj < 6; ++jj){
PotPos[jj] = analogRead(PotPins[jj]);
}// jj
TuneTM = millis();
do {
PotVal = analogRead(PotPins[jj]);
if (abs(PotVal - PotPos[jj]) > MinPotChg){
TuneTM = millis();
PotPos[jj] = PotVal;
ii = jj / 3;
if (ii == 0 && Mirror){PotVal = 1023 - PotVal;}
SemiP[ii].write(map(PotVal, 0, 1023, 0, FullArc));
}// if pot moved
}// jj
LEDlert(1,1); // notify tuning time
} while (TuneTM + Tuning > millis());
} // setup
int iset, ioff, ii, jj, ibutn, potval, mapval;
for (iset = 0; iset < NumSigs; ++iset){
// check timer and skip if not yet expired
if (PosnTM[iset] + HoldMS > millis()){continue;}
ibutn = ioff = iset * 3; // default to red
jj = 0; // # of buttons pushed
// loop through buttons
for (ii = ioff; ii < ioff +3; ++ii){
potval = digitalRead(ButPins[ii]);
if (Trace > 1){
Serial.print("Button ");
Serial.print(ii);
Serial.print(" pin ");
Serial.print(ButPins[ii]);
Serial.print(" value ");
Serial.println(potval);
}// Trace
if (potval == LOW){
++jj;
ibutn = ii;
potval = analogRead(PotPins[ibutn]);
if (iset == 0 && Mirror){potval = 1023 - potval;}
mapval = map(potval, 0, 1023, 0, FullArc);
if (Trace > 0){
Serial.print("Semaphore ");
Serial.print(iset);
Serial.print(" Button ");
Serial.print(ii);
Serial.println(" active");
}// Trace
}// for ii
// done scanning buttons
if (jj > 1){LEDlert(2,10);}// if jj
if (Trace > 0){
Serial.print("Set ");
Serial.print(iset);
Serial.print(" actives ");
Serial.print(jj);
Serial.print(" ibutn ");
Serial.print(ibutn);
Serial.print(" state ");
Serial.println(ServState[iset]);
} // Trace
if (jj == 0 && Latch) {ibutn = ServState[iset];}
// button pushed or latch false
if (ibutn != ServState[iset]
(abs(potval - Posn[iset]) > MinPotChg)
if (Trace > 0){
Serial.print(iset);
Serial.print(ServState[iset]);
Serial.print(" button ");
Serial.print(potval);
Serial.print(" moved to ");
Serial.print(mapval);
Serial.println(" angle ");
} // Trace
// new button state
ServState[iset] = ibutn;
Posn[iset] = potval;
PosnTM[iset] = millis();
SemiP[iset].write(mapval);
if (ibutn == ioff) // RED - call BounceRed
{BounceRed(iset, mapval);}
// Chg 2.2 ^^^^^^^^^^^^^
}// conditions
}// for iset
if (LoopDly > 0){
LEDlert(0,1); // heartbeat
delay(LoopDly);}
} // loop
