Semicolon
Hi, I have a bit of code but I do not understand something
Here is my a part of my code:
if (temperature >= baselineTemp + 22) {
** digitalWrite(2, HIGH);**
** digitalWrite(4, HIGH);**
** digitalWrite(motorPin, HIGH);**
else (temperature <= baselineTemp + 21); {
** digitalWrite(2, LOW);**
** digitalWrite(motorPin, LOW);**
As you can see there is a semicolon in italics, I do not understand why I need to have a semicolon there and not at the other part of the code.
Thanks for any help or suggestions,
Planetoid127
Please use code tags ("</>" button) to post code.
So that it looks like this:
which, incidentally, is not a valid else clause and also should not have a semicolon.
The else statement does not take an argument. If you want to test another condition then use the 'else if' form. Try this code.
Also, you have an extra semicolon at the end of the else:
                  // No semicolon here |
                  //                   V
Edit:
If that’s what you intended, it should be written:
else {
   if (temperature <= baselineTemp + 21) {
      // code controlled by else-if...
A statement can be an expression ending in a semicolon, a statement list in braces, or the various control keyword structures (for, while, if, switch, …).
A semcolon on it’s own is a ‘do nothing’ no-op statement.
When the compiler reads the code you have written, it will interpret it like this:
  ; // do nothing
In other words, the second block will always be executed no matter what the value of temperature.
This is probably not what you meant.
