SEN0161 pH sensor controller help
Good day.
I am developing a pH controller that pumps pH Up or pH down nutrient according to the measured level of pH in a tank.
I have a pH sensor (SEN0161 DFROBOT) which is an analog input for my system that produces pH values upon placement in different liquids.
I would like my pumps to only go on after 10-15 readings from the pH sensor have been produced.
My current code is as follows:
       if (pHValue <5)
          digitalWrite(pHUp,LOW);
          delay(30);
          digitalWrite(pHUp,HIGH);
        if(pHValue>8.5)
          digitalWrite(pHDown,LOW);
          delay(30);
          digitalWrite(pHDown,HIGH);
        if(pHValue>=5 || pHValue<=8.5)
How do I do this?
Regards,
Darshal
Use a counter... increase upon every reading.
Hi there.
What is a counter? How do I use a counter?
Regards,
Just a variable that you increase one at a time.
Thank you.
In terms of using a 'for' loop or using millis() as a timer, what is the difference?
