SEN208\2 Driver board
Heya,
At the moment I'm working with a test boards called SEN208\2.
I have to control 24 NX3DV2567 devices ( SOT1161-1 ) individually. I've already tried to learn the I2C code by watching and reading tutorials but i cant seem to figure it out myself. Somehow everything I think I understand doesn't seem to make sense within the coding.
I would be reall glad if once again someone would like to help me out :slight_smile:
This is the code in it's current state:
#include <SD.h> //Insert SD Library
#include <SPI.h> // Insert SPI communication library
#include <Wire.h>
const int PCA8574PW1 = 0x38;
const int PCA8574PW2 = 0x39;
const int PCA8574PW3 = 0x3A;
float refresh_rate = 0.0; //Set refreshrate, dit is de delay functie. Dit geeft aan hoe snel de data word ontvangen en geschreven.
long id = 1;// Oplopend getal voor alle data.
  Wire.begin();
  Serial.begin(9600);// Begin het programma op 9600baud, dit is nodig voor de COM om text in weer te geven
  Serial.println("Initializing Card");
  pinMode(4, OUTPUT);// Locatie op arduino voor SD pin
  if(!SD.begin(4))
    Serial.println("Card Failed!");
    return;//Indien de SD kaart niet gevonden is geeft aan :Card Failed
  Serial.println("Card Ready.");
  delay(5000);
  File commandFile = SD.open("COMMAND.txt");// Het lezen van de SD card. (Refreshrate)
  if (commandFile)
    Serial.println("Reading Command File");
    float decade = pow(10, (commandFile.available() - 1));
    while(commandFile.available())//programma gaat opzoek naar de Cammond file op de SD kaart
      float temp = (commandFile.read() - '0');
      refresh_rate = temp*decade+refresh_rate;
      decade = decade/10;//Refreshrate van command file omgezet naar hexadecimale getallen
    Serial.print("Refresh Rate = ");
    Serial.print(refresh_rate);
    Serial.println("ms");//refreshrate aangegeven op de COM
    Serial.println("Couldn't read command file.");
    return;
  File logFile = SD.open("CRASH.csv", FILE_WRITE);
  if (logFile)
    logFile.println(", ,");
    String header = "ID, Voltage, Current, Display V, Display A";
    logFile.println(header);
    logFile.close();
    Serial.println(header);// Display op COM van data
    Serial.println("Couldn't open log file");
  delay(10000);
 int val = analogRead(A10);
 int valC = analogRead(A11);// analoge ingangen (zelf aangeven) waar de voltages binnen komen.
  Wire.beginTransmission(PCA8574PW1);
  if (PCA8574PW1 == 0)
  {Serial.println ("No connection!");
  delay(refresh_rate);
  return;
      Wire.write(byte highAddress);
      Wire.write(byte lowAddress);
      float Voltage = val*(5.0/1023.0);
      float Current = valC*(5.0/1023.0);
      float Display = ((val*(5.0/1023.0))*3);
      float DisplayC = ((valC*(5.0/1023.0))*2);
      String dataString = String(id) + ", " + String(Voltage) + ", " + String(Current) + ", " +String(Display) + ", " +String(DisplayC);//Display voor COM en Excel.
  Wire.endTransmission(PCA8574PW1);
  Wire.beginTransmission(PCA8574PW2);
  if (PCA8574PW2 ==0)
  {Serial.println("Lost connection.");
  return;}
  Wire.endTransmission(PCA8574PW2);
  Wire.beginTransmission(PCA8574PW3);
  if (PCA8574PW3 == 0)
  Serial.println("Connection Lost.");
  return;
        File dataFile = SD.open("CRASH.csv", FILE_WRITE);
        if(dataFile)
    dataFile.print(dataString);
    dataFile.close();
    Serial.println(dataString);
    Serial.println("Couldn't create datalog");
 Wire.endTransmission(PCA8574PW3);
  id++;  // code voor het feit dat iedere opgenome waarde i.p.v. 1-1-1-1-1-1-1 is 1-2-3-4-5 word.
  delay (2000);
The description is in dutch for some of my collealues. If necessary i can change that to english.
On forehand thanks!
You've defined that variable as a const int, with a value of 0x38. According to my calculator, 0x38 is not equal to 0, so that if statement will always be false.
Does that even compile? What are you attempting to do here?
After uselessly pissing away resources manipulating Strings, dataString immediately goes out of scope. It's creation was, therefore, a waste of time and effort.
