hi, I want to send the code of my radio control for gates (for example 100101101010 (Bin) or 2410(Dec)).
which library should I use?
how should i write the code?
Thanks in advance
What is sending that code now?
Most semi-modern garage door openers, and gate openers, since they use the same logic, using rolling codes. The sender does not send the same code every time.
the code I wrote is just an example, my gate has a static code
