I have the BT module paired and running. I have a working serial port /dev/tty.RN42-B86B-SPP
What do I type into Mac Terminal program to get the serialEvent() to run?
Serial Event example
When new serial data arrives, this sketch adds it to a String.
When a newline is received, the loop prints the string and
clears it.
A good test for this is to try it with a GPS receiver
that sends out NMEA 0183 sentences.
Created 9 May 2011
by Tom Igoe
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/SerialEvent
String inputString = ""; // a string to hold incoming data
boolean stringComplete = false; // whether the string is complete
#include <Servo.h>
Servo balldropservo; // create servo object to control a servo
// a maximum of eight servo objects can be created
int pos = 0; // variable to store the servo position
// initialize serial:
// reserve 200 bytes for the inputString:
inputString.reserve(200);
balldropservo.attach(9); // attaches the servo on pin 9 to the servo object
pinMode(13, OUTPUT);
// print the string when a newline arrives:
if (stringComplete) {
Serial.println(inputString);
// clear the string:
inputString = "";
SerialEvent occurs whenever a new data comes in the
hardware serial RX. This routine is run between each
time loop() runs, so using delay inside loop can delay
response. Multiple bytes of data may be available.
void serialEvent() {
while (Serial.available()) {
digitalWrite(13, HIGH); // set the LED on
delay(1000); // wait for a second
digitalWrite(13, LOW); // set the LED off
