Send after minute data || send after ten minutes data
Hello. Thanks for coming!
I got two data variables:
data temp1
and data temp2
I want to send the data temp1 every minute, and THEN later of ten minutes, send the data variables to HTTP/POST
using the millis() function but I don't know if is correctly (I solve the post) only I need make the counter. I have the code:
  unsigned long t_actual = 0;
  unsigned long t_corrido = millis();
  const long t_post = 600000;
  Cayenne.run(); //This is the function that sends data to the first post
  if(t_corrido == t_post)
    ToPostWStemp(); //This is the function that sends data to the second post
    t_actual = t_corrido;
  t_actual = 0; //Initialize the actual time from 0
I don't understand the point of this:
because this
already set t_actual to zero. No harm, just redundant.
This:
should be
const unsigned long t_post = 600000;
but no harm, just forces the compiler to deal with it.
This
should be
  if (t_corrido >= t_post)
because there is no guarantee that millis() will ever return 600000. It probably will, but why take the chance?
Halo, vaj... I got a new code, and I guess is so much better than previous...
I tested, but the post doesn't send :S
unsigned long t_cayenne = 0;
unsigned long t_post = 0;
    if (millis() - t_cayenne >= 60000)
        // Do this every 60 seconds
        Cayenne.run();
        // Keep track of the last time this code ran, so we know
        // when to run it next time
        t_cayenne = millis();
    if (millis() - t_post >= 600000)
        ToPostWStemp();
        t_post = millis();
Maclos:
… snip …
You are setting t_cayenne to zero at the start of every loop. Try this:
… snip …
PaulMurrayCbr:
… snip …
I'm not able to see the diferences... :confused: Uhh only change the const outside of loop??
t_cayenne is a variable, not a const.
The loop() function gets executed over and over again. Defining t_cayenne outside of a function (that is, declared globally) sets t_cayenne to zero once and allows it to preserve its value instead of repeatedly being reset to zero.
I love U guys, tomorro I'll test the code... I feel like stupid ._. THANKS FELLAS! I'll tell you how's going everything
