Send and Receive numerical data (int) via LoRa
Hey folks! New to LoRa, and really not that great at coding, so I generally splice together other code and work between it all.
Using Adafruit Feather 32u4
I have 2 numbers that I am gathering and want to transmit, and have the other side see as number so it can do extra math from its own gathered data. Below is the TX and the RX code I am using. The TX code has a place holder data set, DataSend, that contains two numbers that will need to be int sized.
RX I have not done anything to as everything I try throws crazy errors. It is built to show stuff as characters, but that won't work for doing math.
Any tips on what to do, or how to receive that array and be able to split the numbers out?
TX:
#include <SPI.h>
#include <RH_RF95.h>
  #define RFM95_CS    8
  #define RFM95_INT   7
  #define RFM95_RST   4
// Change to 434.0 or other frequency, must match RX's freq!
#define RF95_FREQ 915.0
// Singleton instance of the radio driver
RH_RF95 rf95(RFM95_CS, RFM95_INT);
  pinMode(RFM95_RST, OUTPUT);
  digitalWrite(RFM95_RST, HIGH);
  delay(100);
  Serial.println("Feather LoRa TX Test!");
  // manual reset
  digitalWrite(RFM95_RST, LOW);
  delay(10);
  delay(10);
  while (!rf95.init()) {
    Serial.println("LoRa radio init failed");
    Serial.println("Uncomment '#define SERIAL_DEBUG' in RH_RF95.cpp for detailed debug info");
    while (1);
  Serial.println("LoRa radio init OK!");
   if (!rf95.setFrequency(RF95_FREQ)) {
    Serial.println("setFrequency failed");
    while (1);
  Serial.print("Set Freq to: "); Serial.println(RF95_FREQ);
  // The default transmitter power is 13dBm, using PA_BOOST.
  // If you are using RFM95/96/97/98 modules which uses the PA_BOOST transmitter pin, then
  // you can set transmitter powers from 5 to 23 dBm:
  rf95.setTxPower(23, false);
int16_t packetnum = 0;  // packet counter, we increment per xmission
  delay(1000); // Wait 1 second between transmits, could also 'sleep' here!
  Serial.println("Transmitting..."); // Send a message to rf95_server
  int DataSend[2]={123,789};
  Serial.println("Sending...");
  delay(10);
  rf95.send((uint8_t *)&DataSend, sizeof(DataSend));
  Serial.println("Waiting for packet to complete...");
  delay(10);
  rf95.waitPacketSent();
  // Now wait for a reply
  uint8_t buf[RH_RF95_MAX_MESSAGE_LEN];
  uint8_t len = sizeof(buf);
  Serial.println("Waiting for reply...");
  if (rf95.waitAvailableTimeout(1000)) {
    // Should be a reply message for us now
    if (rf95.recv(buf, &len)) {
      Serial.print("Got reply: ");
      Serial.println((char*)buf);
      Serial.print("RSSI: ");
      Serial.println(rf95.lastRssi(), DEC);
      Serial.println("Receive failed");
    Serial.println("No reply, is there a listener around?");
RX:
#include <SPI.h>
  #define RFM95_CS    8
  #define RFM95_INT   7
  #define RFM95_RST   4
  pinMode(LED_BUILTIN, OUTPUT);
  delay(100);
  Serial.println("Feather LoRa RX Test!");
  // manual reset
  delay(10);
  delay(10);
    while (1);
    while (1);
  if (rf95.available()) {
    // Should be a message for us now
      digitalWrite(LED_BUILTIN, HIGH);
      RH_RF95::printBuffer("Received: ", buf, len);
      Serial.print("Got: ");
      // Send a reply
      uint8_t data[] = "And hello back to you";
      rf95.send(data, sizeof(data));
      Serial.println("Sent a reply");
      digitalWrite(LED_BUILTIN, LOW);
transmitting multiple values using structures enables error checking using sequence numbers (checking for lost packates etc)
e.g. transmitter using the lora.h library
// Lora transmit a structure
#include <SPI.h>
#include <LoRa.h>
struct Data {
  int seq;
  float y;
Data data={0 , 4.5};
  while (!Serial);
  Serial.println("LoRa Sender");
  //  void setPins(int ss = LORA_DEFAULT_SS_PIN, int reset = LORA_DEFAULT_RESET_PIN, int dio0 = LORA_DEFAULT_DIO0_PIN);
  LoRa.setPins(8, 4, 7); // for Lora 32u4
  if (!LoRa.begin(866E6)) {
    Serial.println("Starting LoRa failed!");
    while (1);
  Serial.print("\nSending packet: ");
   Serial.print("seq = ");
    Serial.print(data.seq);
    Serial.print(" y = ");
    Serial.println(data.y);
  // send packet
  LoRa.beginPacket();
  LoRa.write((byte *)&data, sizeof(data));
  for (unsigned int i = 0; i < sizeof(Data);i++) {
    Serial.print(' ');
    //LoRa.write(((byte *) &data)[i]);
    Serial.print(((byte *) &data)[i]);
  LoRa.endPacket();
  data.seq += 1;
  data.y += 10;
  delay(50);
receiver
// Lora receive a structure containg seq number and a flaot
#include <SPI.h>
#include <LoRa.h>
struct Data {
  int seq;
  float y;
} data;
  while (!Serial)
  Serial.println("LoRa Receiver");
    while (1)
  static int counter = 0, errors = 0, seq = 0;
  // try to parse packet
  int packetSize = LoRa.parsePacket();
  if (packetSize) {
    // received a packet
    Serial.print("\nReceived packet size ");
    Serial.print(packetSize);
    Serial.print(" data ");
    LoRa.readBytes((byte *)&data, packetSize);
    // read packet
    //while (LoRa.available())
    for (int i = 0; i < packetSize; i++) {
      // ((byte *) &data)[i] = LoRa.read();
      Serial.print(' ');
      Serial.print(((byte *)&data)[i]);
    // print RSSI of packet
    Serial.print("' with RSSI ");
    Serial.println(LoRa.packetRssi());
    Serial.print(data.y);
    Serial.print(" received ");
    Serial.print(++counter);
    Serial.print(" errors ");
    Serial.println(errors);
    if (seq != data.seq) {
      Serial.print("sequence number error expected ");
      Serial.println(seq);
      seq = data.seq;
      errors++;
    seq++;
results
transmitter
Sending packet: seq = 1 y = 14.50
 1 0 0 0 104 65
Sending packet: seq = 2 y = 24.50
 2 0 0 0 196 65
Sending packet: seq = 3 y = 34.50
 3 0 0 0 10 66
Sending packet: seq = 4 y = 44.50
 4 0 0 0 50 66
Sending packet: seq = 5 y = 54.50
 5 0 0 0 90 66
Sending packet: seq = 6 y = 64.50
 6 0 0 0 129 66
Sending packet: seq = 7 y = 74.50
 7 0 0 0 149 66
Sending packet: seq = 8 y = 84.50
Sending packet: seq = 76 y = 764.50
 76 0 0 32 63 68
Sending packet: seq = 77 y = 774.50
 77 0 0 160 65 68
Sending packet: seq = 78 y = 784.50
 78 0 0 32 68 68
Sending packet: seq = 79 y = 794.50
 79 0 0 160 70 68
Sending packet: seq = 80 y = 804.50
 80 0 0 32 73 68
Sending packet: seq = 81 y = 814.50
 81 0 0 160 75 68
Sending packet: seq = 82 y = 824
receiver
LoRa Receiver
Received packet size 6 data  0 0 0 0 144 64' with RSSI -72
seq = 0 y = 4.50 received 1 errors 0
Received packet size 6 data  1 0 0 0 104 65' with RSSI -73
seq = 1 y = 14.50 received 2 errors 0
Received packet size 6 data  2 0 0 0 196 65' with RSSI -73
seq = 2 y = 24.50 received 3 errors 0
Received packet size 6 data  3 0 0 0 10 66' with RSSI -73
seq = 3 y = 34.50 received 4 errors 0
Received packet size 6 data  4 0 0 0 50 66' with RSSI -72
seq = 4 y = 44.50 received 5 errors 0
Received packet size 6 data  5 0 0 0 90 66' with RSSI -72
seq = 5 y = 54.50 received 6 errors 0
Received packet size 6 data  6 0 0 0 129 66' with RSSI -72
seq = 6 y = 64.50 received 7 errors 0
Received packet size 6 data  7 0 0 0 149 66' with RSSI -72
seq = 7 y = 74.50 received 8 errors 0
Received packet size 6 data  8 0 0 0 169 66' with RSSI -72
seq = 8 y = 84.50 received 9 errors 0
Received packet size 6 data  89 0 0 160 95 68' with RSSI -73
seq = 89 y = 894.50 received 90 errors 0
Received packet size 6 data  90 0 0 32 98 68' with RSSI -69
seq = 90 y = 904.50 received 91 errors 0
Received packet size 6 data  91 0 0 160 100 68' with RSSI -72
seq = 91 y = 914.50 received 92 errors 0
Received packet size 6 data  92 0 0 32 103 68' with RSSI -72
seq = 92 y = 924.50 received 93 errors 0
Received packet size 6 data  93 0 0 160 105 68' with RSSI -72
seq = 93 y = 934.50 received 94 errors 0
example using Radiohead library
UNO transmitter using a LoRa shield
// RH_RF95 - UNO with Dragino LoRa shield -  transmit a structure
// -*- mode: C++ -*-
// Example sketch showing how to create a simple messaging client (transmitter)
// with the RH_RF95 class. RH_RF95 class does not provide for addressing or
// reliability, so you should only use RH_RF95 if you do not need the higher
// level messaging abilities.
// It is designed to work with the other example Feather9x_RX
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#define SEALEVELPRESSURE_HPA (1013.25)
struct __attribute__((packed)) BME280 {
  byte StructureID;  // identifies the structure type
  byte NodeID;       // ID of transmitting node
  int16_t seq;       // sequence number
  float temperature;
  float pressure;
  float altitude;
  float humidity;
} bme280 = { 1, 1, 0, 23.0, 1000.0, 100.0, .5 };
Adafruit_BME280 bme;  // I2C
//Adafruit_BME280 bme(BME_CS); // hardware SPI
//Adafruit_BME280 bme(BME_CS, BME_MOSI, BME_MISO, BME_SCK); // software SPI
/* for feather32u4 */
/*#define RFM95_CS 8
#define RFM95_RST 4
#define RFM95_INT 7*/
/* for feather m0
#define RFM95_CS 8
#define RFM95_RST 4
#define RFM95_INT 3
/* for shield */
#define RFM95_CS 10
#define RFM95_RST 9
#define RFM95_INT 2
/* for ESP w/featherwing
#define RFM95_CS  2    // "E"
#define RFM95_RST 16   // "D"
#define RFM95_INT 15   // "B"
/* Feather 32u4 w/wing
#define RFM95_RST     11   // "A"
#define RFM95_CS      10   // "B"
#define RFM95_INT     2    // "SDA" (only SDA/SCL/RX/TX have IRQ!)
/* Feather m0 w/wing
#define RFM95_INT     6    // "D"
/* Teensy 3.x w/wing
#define RFM95_RST     9   // "A"
#define RFM95_INT     4    // "C"
#define RF95_FREQ 868.0
int BME280ok = 1;
  Wire.setClock(400000);
  while (!Serial)
  delay(100);
  Serial.println("Uno LoRa shield BME280 TX Test!");
  int status = bme.begin(0x76);
  if (!status) {
    Serial.println("Could not find a valid BME280 sensor, check wiring!");
    //while (1) delay(10);
    BME280ok = 0;  // indicate failed
  } else Serial.println("BME280 sensor, found!");
  // manual reset
  delay(10);
  delay(10);
    while (1)
  // Defaults after init are 434.0MHz, modulation GFSK_Rb250Fd250, +13dbM
    while (1)
  // Defaults after init are 434.0MHz, 13dBm, Bw = 125 kHz, Cr = 4/5, Sf = 128chips/symbol, CRC on
  if (BME280ok) {  // if BME280 connected read data
    bme280.temperature = bme.readTemperature();
    bme280.pressure = bme.readPressure() / 100.0F;
    bme280.altitude = bme.readAltitude(SEALEVELPRESSURE_HPA);
    bme280.humidity = bme.readHumidity();
  } else {  // if not connected generate data
    bme280.temperature += 1.0;
    bme280.pressure += 10.0;
    bme280.altitude -= 3.0;
    bme280.humidity += 1.0;
  Serial.println("Sending BME280 data to  to rf95_server");
  Serial.print("seq ");
  Serial.print(++bme280.seq);
  Serial.print(" Temperature = ");
  Serial.print(bme280.temperature);
  Serial.print("*C");
  Serial.print(" Pressure = ");
  Serial.print(bme280.pressure);
  Serial.print("hPa");
  Serial.print(" Approx. Altitude = ");
  Serial.print(bme280.altitude);
  Serial.print("m");
  Serial.print(" Humidity = ");
  Serial.print(bme280.humidity);
  Serial.println("%");
  rf95.send((byte *)&bme280, sizeof(bme280));
  delay(10);
  delay(10);
      Serial.println((char *)buf);
  delay(3000);
receiver using a Feather 32u4
// RH_RF95 - Adafruit Feather 32u4 LoRa - receive a structure
// Example sketch showing how to create a simple messaging client (receiver)
// It is designed to work with the other example Feather9x_TX
#include <SPI.h>
  float temperature;
  float pressure;
  float altitude;
  float humidity;
} bme280;
#define RFM95_CS 8
#define RFM95_RST 4
#define RFM95_INT 7
/* for feather m0
#define RFM95_CS 8
#define RFM95_RST 4
#define RFM95_INT 3
/* for shield
#define RFM95_CS 10
#define RFM95_RST 9
#define RFM95_INT 2
// Blinky on receipt
#define LED 13
  pinMode(LED, OUTPUT);
  while (!Serial)
  delay(100);
  // manual reset
  delay(10);
  delay(10);
    while (1)
    while (1)
    uint8_t len = sizeof(bme280);
    if (rf95.recv((byte *)&bme280, &len)) {
      digitalWrite(LED, HIGH);
      RH_RF95::printBuffer("Received: ", (byte *)&bme280, len);
      if(len != sizeof(bme280)) {
        Serial.println("***** packet wrong length! *****");
        return;
      Serial.print(rf95.lastRssi(), DEC);
      Serial.print(" seq ");
      Serial.print(bme280.seq);
      Serial.print("*C ");
      // Convert temperature to Fahrenheit
      Serial.print(1.8 * bme280.temperature + 32);
      Serial.print("*F");
      Serial.print("m");
      delay(10);
      static int16_t seqExpected = 0, seqErrors = 0;
      if (bme280.seq != seqExpected) {  // check for sequence error!
        Serial.print(" ***** seq number error expected ");
        Serial.print(seqExpected);
        Serial.print("  seq  errors ");
        Serial.println(++seqErrors);
        seqExpected = bme280.seq;
      seqExpected++;  // next sequence nunber expected
      // Send a reply
      delay(200);  // may or may not be needed
      uint8_t data[] = "receive OK";
      digitalWrite(LED, LOW);
results
transmitter
LoRa radio init OK!
Set Freq to: 868.00
seq 1 Temperature = 21.27*C Pressure = 1019.87hPa Approx. Altitude = -54.98m Humidity = 44.49%
Got reply: receive OK
RSSI: -98
seq 2 Temperature = 21.28*C Pressure = 1019.87hPa Approx. Altitude = -55.01m Humidity = 44.37%
RSSI: -98
seq 3 Temperature = 21.29*C Pressure = 1019.91hPa Approx. Altitude = -55.27m Humidity = 44.38%
RSSI: -98
seq 4 Temperature = 21.28*C Pressure = 1019.92hPa Approx. Altitude = -55.35m Humidity = 44.27%
receiver
LoRa radio init OK!
Set Freq to: 868.00
Received:
1 1 1 0 71 3D A8 41 56 F8 7E 44 BA 37 5C C2
0 E2 3A 42
RSSI: -106 seq 1 Temperature = 21.03*C 69.85*F Pressure = 1019.88hPa Approx. Altitude = -55.05m Humidity = 46.72%
 ***** seq number error expected 40 received 1  seq  errors 18
Sent a reply
Received:
1 1 2 0 0 0 AA 41 AD F7 7E 44 25 E1 5B C2
0 0 35 42
RSSI: -106 seq 2 Temperature = 21.25*C 70.25*F Pressure = 1019.87hPa Approx. Altitude = -54.97m Humidity = 45.25%
Sent a reply
Received:
1 1 3 0 7B 14 AA 41 3A FA 7E 44 F 36 5D C2
0 3C 33 42
RSSI: -106 seq 3 Temperature = 21.26*C 70.27*F Pressure = 1019.91hPa Approx. Altitude = -55.30m Humidity = 44.81%
Sent a reply
Received:
1 1 4 0 71 3D AA 41 74 F7 7E 44 16 C6 5B C2
0 4F 32 42
RSSI: -106 seq 4 Temperature = 21.28*C 70.30*F Pressure = 1019.87hPa Approx. Altitude = -54.94m Humidity = 44.58%
Sent a reply
Received:
1 1 5 0 71 3D AA 41 C F9 7E 44 21 99 5C C2
0 CA 31 42
RSSI: -106 seq 5 Temperature = 21.28*C 70.30*F Pressure = 1019.89hPa Approx. Altitude = -55.15m Humidity = 44.45%
Sent a reply
on the initial communication a sequence number error is displayed as the sequence numbers synchronise
This is exactly what I needed, thank you! I am going to dig and learn WHY this works, but now I have something that DOES work so I can start playing (swapping devices between transmit and receive, send through desired data, etc). Thanks again!
