Hiddenvision:
There was an example of some websocket stuff using a couple of ESP8266 modules.
https://forum.arduino.cc/index.php?topic=630014.0
Sort of similar enough to be worth a look perhaps unless you have gone passed that point now.
thank you for your care !!
I used the websocket library
but i’m still stuck they supposed to connect to my router … actually i need them to be connected in a chain… all are in WiFi_AP_STA mode
I tried to connect two esp8266 (esp-01) one as an access point. they connected successfully but the messages are not exchanged and then after seconds… the second esp-01 shows in the serial monitor:
[WSc] Disconnected!
please can you take a look what could be the problem
server code:
#include <Arduino.h>
#include <ESP8266WiFi.h>
#include <ESP8266WiFiMulti.h>
#include <WebSocketsServer.h>
#include <Hash.h>
ESP8266WiFiMulti WiFiMulti;
WebSocketsServer webSocket = WebSocketsServer(81);
#define USE_SERIAL Serial
void webSocketEvent(uint8_t num, WStype_t type, uint8_t * payload, size_t length) {
switch(type) {
case WStype_DISCONNECTED:
USE_SERIAL.printf("[%u] Disconnected!\n", num);
case WStype_CONNECTED:
IPAddress ip = webSocket.remoteIP(num);
USE_SERIAL.printf("[%u] Connected from %d.%d.%d.%d url: %s\n", num, ip[0], ip[1], ip[2], ip[3], payload);
// send message to client
webSocket.sendTXT(num, "message from the server");
case WStype_TEXT:
USE_SERIAL.printf("[%u] get Text: %s\n", num, payload);
// webSocket.sendTXT(num, "message here");
// send data to all connected clients
// webSocket.broadcastTXT("message here");
case WStype_BIN:
USE_SERIAL.printf("[%u] get binary length: %u\n", num, length);
hexdump(payload, length);
// webSocket.sendBIN(num, payload, length);
// USE_SERIAL.begin(921600);
USE_SERIAL.begin(115200);
//Serial.setDebugOutput(true);
USE_SERIAL.setDebugOutput(true);
USE_SERIAL.println();
for(uint8_t t = 4; t > 0; t--) {
USE_SERIAL.printf("[SETUP] BOOT WAIT %d...\n", t);
USE_SERIAL.flush();
WiFi.mode(WIFI_AP_STA);
WiFi.softAP("SSID", "passpasspass");
delay(300);
webSocket.begin();
webSocket.onEvent(webSocketEvent);
webSocket.loop();
client code:
#include <WebSocketsClient.h>
#include <Hash.h>
WebSocketsClient webSocket;
void webSocketEvent(WStype_t type, uint8_t * payload, size_t length) {
switch(type) {
USE_SERIAL.printf("[WSc] Disconnected!\n");
case WStype_CONNECTED: {
USE_SERIAL.printf("[WSc] Connected to url: %s\n", payload);
// send message to server when Connected
webSocket.sendTXT("Connected");
case WStype_TEXT:
USE_SERIAL.printf("[WSc] get text: %s\n", payload);
// webSocket.sendTXT("message here");
case WStype_BIN:
USE_SERIAL.printf("[WSc] get binary length: %u\n", length);
// send data to server
// webSocket.sendBIN(payload, length);
case WStype_PING:
// pong will be send automatically
USE_SERIAL.printf("[WSc] get ping\n");
case WStype_PONG:
// answer to a ping we send
USE_SERIAL.printf("[WSc] get pong\n");
USE_SERIAL.flush();
WiFiMulti.addAP("SSID", "passpasspass");
//WiFi.disconnect();
while(WiFiMulti.run() != WL_CONNECTED) {
USE_SERIAL.print("..");
delay(100);
// server address, port and URL
webSocket.begin("192.168.4.2", 81, "/");
// event handler
// use HTTP Basic Authorization this is optional remove if not needed
// webSocket.setAuthorization("user", "Password");
// try ever 5000 again if connection has failed
webSocket.setReconnectInterval(5000);
// start heartbeat (optional)
// ping server every 15000 ms
// expect pong from server within 3000 ms
// consider connection disconnected if pong is not received 2 times
webSocket.enableHeartbeat(15000, 3000, 2);
webSocket.loop();
