Send correct data to SC
Hi there,
I have a sensor that reads the light. the sensor is connected to Analog 1.
in Serial Monitor when I print the "light level" I get values from 0 to ~5 as the datasheet refers.
But when I load standar firmata and I connected with sc I get other values 0 - ~632 in SC
why this is happening?
how it is possible to receive the actual values in SC that my arduino sketch reads?
Strange... can you post your sketch?
here is the arduino code:
#include <Wire.h> //I2C needed for sensors
//Pin definitions
// digital I/O pins
const byte STAT1 = 7;
const byte STAT2 = 8;
// analog I/O pins
const byte LIGHT = A1;
const byte REFERENCE_3V3 = A3;
//=-=-=-=-=-=-=-=-=-=-= Global Variables =-=-=-=-=-=-=-=-=-=-=\\
long lastSecond; //The millis counter to see when a second rolls by
byte seconds; //When it hits 60, increase the current minute
float light_lvl = 455; //[analog value from 0 to 1023]
  Serial.println("Weather Shield Example");
  pinMode(STAT1, OUTPUT); //Status LED Blue
  pinMode(STAT2, OUTPUT); //Status LED Green
  pinMode(LIGHT, INPUT);
  seconds = 0;
  lastSecond = millis();
  // attach external interrupt pins to IRQ functions
  // turn on interrupts
  interrupts();
  Serial.println("Weather Station online! :)");
  //Keep track of which minute it is
  if(millis() - lastSecond >= 1000)
    digitalWrite(STAT1, HIGH); //Blink stat LED
    lastSecond += 1000;
    //Calc the wind speed and direction every second for 120 second to get 2 minute average
        calcWeather();
    digitalWrite(STAT1, LOW); //Turn off stat LED
  delay(100);
//light function
void calcWeather() {
  //Get light level
  light_lvl = get_light_level();
  Serial.print(" | Light level = ");
  Serial.println(light_lvl, 2);
//Read the light level
float get_light_level()
  float operatingVoltage = analogRead(REFERENCE_3V3);
  float lightSensor = analogRead(LIGHT);
  operatingVoltage = 3.3 / operatingVoltage; //The reference voltage is 3.3V
  lightSensor = operatingVoltage * lightSensor;
  return(lightSensor);
And here is the SC code
SCPyduino
SerialPort.listDevices
// Connect with arduino
	~connectArduino = Routine{
		~arduino = SCPyduino.new("/dev/tty.usbmodem1421", 9600);
		4.wait;
		"The Firmata firmware version on this Arduino board is: ".post;
		~arduino.firmataVersion.postln}.play;
//activate the analog pin
~arduino.analog[1].active_(1);
~arduinoLoop = {loop {
	~arduino.iterate;
	~arduino.analog[1].value.postln;
}}.fork;
Arduino serial monitors reads 0 to 3.3 because the light sensor is based on the 3.3V rail
In Supercollider I am reading from Analog 1 but I get values from 0 to ~632
As the Arduino multiplexes the analogReads they affect each other. Could be a cause One way to handle this is to do multiple reads and throw away the first one.
  analogRead(REFERENCE_3V3);  // dummy read
  analogRead(LIGHT); // dummy read
  return analogRead(LIGHT) * 3.3 / operatingVoltage;
632 / 3.3 * 5.0 = 957 ( comes close to 1023) could that be a cause?
632 just being the max value for 3.3 volt
