Send data by Bluetooth with a push Button
Hello,
I have an Arduino Nano with a push button, a led, a buzzer and a bluetooth module (https://hackspark.fr/fr/hc-05-bluetooth-v2-0-breakout-board-host-and-slave-3-6-6v.html).
I want to activate the led and the buzzer when I push the button, and at the same time, send a message with the bluetooth.
Unfortunately, when I push the button, the message is not sent. I think that the bluetooth is unabled when the led and the buzzer run, maybe because of power limits. On the other side, the message is sent when I don’t push the button (see the test “I am a test” in the code below).
Here is my code :
#include <SoftwareSerial.h>
const int buzzer1 = 2;
const int buzzer2 = 3;
const int led = 4;
const int button = 5;
int buttonState = 0;
int buttonLastState = 0;
// Declaration of bluetooth RX and TX
SoftwareSerial Bluetooth(10, 11);
  pinMode(led, OUTPUT);
  pinMode(buzzer1,OUTPUT);
  pinMode(buzzer2,OUTPUT);
  pinMode(button, INPUT);
  Bluetooth.begin(9600);
  buttonState = digitalRead(button);
  // Send text by bluetooth
  Bluetooth.println("I am a test !");
  bluetoothFunc(buttonState);
  // Activate led and buzzer
  ring(buttonState);
void bluetoothFunc(int buttonState)
  if (Bluetooth.available())
  if (buttonLastState != buttonState) {
    if (buttonState == 1) {
      Bluetooth.write('2');
      buttonLastState = buttonState;
void ring(int buttonState)
  digitalWrite(buzzer2, LOW);
  if (buttonState == HIGH) {
    digitalWrite(led, HIGH);
    digitalWrite(buzzer1, HIGH);
    digitalWrite(buzzer2, HIGH);
    delay(40);
    digitalWrite(led, LOW);
    digitalWrite(buzzer1, LOW);
    delay(40);
  else {
Why does sending data depend on there being data to read?
PaulS:
I thought that it was to check if bluetooth module was running. But even when I remove it, there is the same problem.
When I push the button, the led on the bluetooth module turns off.
