Send data form multipel sensors to PC via serial Connection,C# app for analyze
i want to send 3 sensor data to pc via Serial Connection ... And analyze the data using C# app ...
I Still dont know the theory of sending multiple values .. So any idea to do that ???
Permission is hereby granted. Proceed.
And yet you've figured out to type multiple words in such a way that others can understand them. Am I missing something?
Send a value. Send a delimiter. Repeat as many times as needed.
But of course.
Devise some kind of protocol that allows the C# program to figure out which reading is which. A simple way is:
<32.1,45.0,23.9>
So you have a start of packet and end of packet marker and comma separated readings. You know which is which, so you can parse out the readings in your C# code. You can add checksums, acknowledgment, named parameters etc. etc, but that basic method should get you started.
thanx for the advice....
I want to send readings from 2 ultrasound Sensors....
#define echo1 7
#define trig1 12
#define echo2 3
#define trig2 13
long dis1,pulse1,dis2,pulse2;
pinMode(echo1,INPUT);
pinMode(trig1,OUTPUT);
pinMode(echo2,INPUT);
pinMode(trig2,OUTPUT);
digitalWrite(trig1,LOW);
delayMicroseconds(10);
digitalWrite(trig1,HIGH);
pulse1=pulseIn(echo1,HIGH);
dis1=pulse1/58.2;
digitalWrite(trig2,LOW);
digitalWrite(trig2,HIGH);
pulse2=pulseIn(echo2,HIGH);
dis2=pulse2/58.2;
Serial.write(int(dis1));
Serial.write(int(dis2));
I need a C# programme to catch these data ...
IS THIS OK ???
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
using System.IO.Ports;
namespace WindowsFormsApplication6
public partial class Form1 : Form
SerialPort port = new SerialPort("COM15", 9600);
string rawdata;
string[] data;
public Form1()
InitializeComponent();
private void button1_Click(object sender, EventArgs e)
try
port.Open();
catch
MessageBox.Show("Error of Opening tjhe Ports", "Atention");
while (port.IsOpen)
data = port.ReadLine().Split(',');
textBox1.Text = data[0];
textBox2.Text = data[1];
So, instead of writing a function, I'm just going to duplicate the code.
IS THIS OK ???
No. The sender is sending binary data with no delimiters. The C# application is expecting ASCII data separated by a comma.
The sender needs to use:
  Serial.print(dis1);
  Serial.print(",");
  Serial.println(dis2);
Note the use of println for the last value, to add the carriage return and line feed that ReadLine() is expecting.
