Hi guys, i just tried to make a project but i've failed and i'm starting again from zero.
I need some suggestion how can i do this project...
What i need to do? If i press a button connected to an esp8266, another esp8266 will print a message on a led monitor.
I've made the code for button, the code for the monitor but my problem is how can i send the value pressed from an esp8266 to another.
Bot esp8266 need to connect to a wifi router (the distance doesn't permit the direct connection between them).
I search but i don't know where i can get the best solution...
What do you suggest to connect them?
Your topic was MOVED to its current forum category as it is more suitable than the original as it is not a suggestion for the Arduino project itself
Try this:
