Hi! An total beginner here. I am trying to understand whether it is possible to send data like the steps count from health app to trigger some action on arduino (for example if the step count is 1000 a light will turn on etc.)?
This is more of an apple problem than an Arduino one. All you need is an app that will send the step data to Bluetooth, or maybe just a serial cable.
you could implement your own health app using MIT Inventor
I can use any app that counts the steps and it can send the data to arduino? Can you explain to me briefly how that can be made possible? Thank you!
Thank you for the suggestion, I will take a look!
if you do a web search for mit app inventor health app you will get plenty of links
No. You can use any app that is capable of sending data to another party. Determining which app that might be is down to you. The most obvious choice is serial data. If your app can send data to a PC serial port, it can send the same data to Arduino.
Apple is more at fault here than Arduino is. All you need is a Bluetooth-capable app to deliver step data, or even simply a serial cord.
Thank You
Yes, it's possible. You can use a Bluetooth module to connect your smartphone to an Arduino. Develop a mobile app to read step count data from the Health app and send it to the Arduino. Then, program the Arduino to perform actions based on the received step count, like turning on a light.
you are absolutely right.
Yes, it's possible! You can use a Bluetooth module to connect your smartphone to an Arduino. Then, develop a mobile app to read step count data from the Health app and send it to the Arduino. Finally, program the Arduino to perform actions like turning on a light when the step count reaches a certain threshold, such as 1000 steps.
