Send Data from Arduino Nano ESP32 to SIMULINK
Hi Everyone. I need help with the following problem I am having. I am using an “Arduino Nano ESP32”, which has a TMP36 temperature sensor connected to the Analog A0 pin. That temperature measurement I need to have it in real time in the SIMULINK (2024b) program. This means that, I need that temperature data to travel from the “Arduino Nano ESP32” to my SIMULINK (on my PC) wirelessly. The reason why it must be wireless, is because I already have the PCB assembled, and I have a 12V power supply that feeds the whole PCB and therefore my Arduino through the VIN pin (I think I can't simultaneously connect to my Arduino a USB cable and feed it through VIN); then I want to be able to send the temperature signal or data from the Arduino to SIMULINK.
I need help with the step by step, so the data can be sent.
Note: the goal of my project is to develop a temperature control, where the PID controller will be developed in SIMULINK blocks and the responses obtained (Variables to manipulate) will be sent back to the ARDUINO to increase or decrease the power of a device such as the fan or electrical resistance.
I think if you can build all that, adding some client/server code for which there are hundreds, if not more, examples would be a piece of cake. I am not a web guy but here is the list of examples for that board.
