Send data in server -> error connections
Hello :slight_smile:
I’m trying to send data into my personal server but my connection failed.
#include <SPI.h>
#include <Ethernet.h>
#include <SoftwareSerial.h>
byte mac[] = { 0x90, 0xA2, 0xDA, 0x0D, 0xF9, 0x81 };
IPAddress ip(192, 168, 0, 16);
char server[] = "www.martin_valentin.fr";
EthernetClient client;
SoftwareSerial cptSerial(2, 3);
#define startFrame 0x02
#define endFrame 0x03
#define startLine 0x0A
#define endLine 0x0D
  cptSerial.begin(1200);
  Ethernet.begin(mac, ip);
String GetTeleInfo()
    String TeleInfo = "";
    char charIn = 0;
    while (charIn != startLine)
        charIn = cptSerial.read() & 0x7F;
    while (charIn != endLine)
        if (cptSerial.available() > 0)
            TeleInfo += charIn;
    return TeleInfo;
String ShowTeleInfo(String keyword, String unit, int length)
    int essai = 0;
    // Nombre d'étiquettes maximum, cf documentation ERDF
    int max_essais = 33;
    String data = "";
    String msg = "";
    while(data.substring(0,keyword.length()) != keyword && essai != max_essais)
        data = GetTeleInfo();
        essai++;
    msg = "\t<";
    msg += keyword;
    msg += " unit=\"";
    msg += unit;
    msg += "\">";
    if (essai != max_essais)
        msg += data.substring((keyword.length() + 1),(length + (keyword.length() + 1)));
        msg += "NA";
    msg += "</";
    msg += keyword;
    msg += ">";
    return msg;
  boolean current_line_is_blank = true;
  if(client.connect(server, 80)) {
    Serial.println("-> Connected");
    char c = client.read();
    if (c == '\n' && current_line_is_blank)
      client.print("GET /teleinfo/[i]send_data.php[/i]?");
      client.print("ADCO=");
      client.print(ShowTeleInfo("ADCO","",12));
      client.print("&&");
      client.print("OPTARIF=");
      client.print(ShowTeleInfo("OPTARIF","",4));
      client.print("&&");
      client.print("ISOUSC=");
      client.print(ShowTeleInfo("ISOUSC","A",2));
      client.println(" HTTP/1.1");
      client.println("Host: www.martin_valentin.fr");
      client.println("Connection: close");
      client.println();
      client.println();
      client.stop();
    if (c == '\n')
    else if (c != '\r')
        current_line_is_blank = false;
    Serial.println("--> connection failed\n");
  delay(200);
  client.stop();
On my console, I have ‘’–> connection failed".
I don’t know where is my error. Are you an idea?
Thanks a lot for your helps
Valentin :wink:
Je vous refais ca en Francais :)
J'ai branché par ethernet mon arduiono uno avec un ethernet shield officiel sur le port ethernet de mon ordinateur. Je n'ai rien configurer d'autres.
Je chercher à envoyer par GET mes données de téléinfo sur la base de donnée Mysql de mon serveur personnel. La page "send_data.php" recevant les données et les insérant dans la base de donnée.
Mon soucis est que dans loop(), l'envoie ne se fait pas et m'affiche directement "--> connection failed". Je pense donc avoir mal configuré mon ethernet ou il manque une info mais je ne vois pas où est le soucis.
Je vous remercie d'avance pour votre aide :)
