send data string to web server from arduino + xbee
Hi I’m new here, and I faced with the problem. I want to receive the data string and redundant data is coming in the form of char. Here my code ethernet + xbee
 #include <SPI.h>
#include <Ethernet.h>
#include <SoftwareSerial.h>
SoftwareSerial XBee (8,7);
// assign a MAC address for the ethernet controller.
// fill in your address here:
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
char inChar = Serial.read();
EthernetClient client;
char server[] = "192.168.0.121";
int i;
  XBee.begin(19200);
  Serial.begin(19200);
  Ethernet.begin(mac);
  Serial.print("IP Address        : ");
  Serial.println(Ethernet.localIP());
char data =XBee.read();
if (Serial.available())
  { // If data comes in from serial monitor, send it out to XBee
    XBee.write(Serial.read());
  if (XBee.available())
  { // If data comes in from XBee, send it out to serial monitor
    Serial.write(XBee.read());
    char c = XBee.read();
  if (client.connect(server,80)) {
    client.print( "GET /test/add_data.php?");
    client.print("kelas=");
    client.print(inChar);
    client.print("&&");
    client.print("data=");
    client.print( c );
    client.println( " HTTP/1.1");
    client.print( "Host: " );
    client.println(server);
    client.println( "Connection: close" );
    client.println();
    client.println();
    client.stop();
    }else {
    Serial.println("connection failed");
    Serial.println("disconnecting.");
    delay(10000);
i cannot use array in data receiver from xbee. here my xbee sender with ethernet and sdcard
#include <SPI.h>
#include <SD.h>
File myFile;
byte mac[] = {
  0x90, 0xA2, 0xDA, 0x00, 0xE3, 0xE0 };
IPAddress ip(192,168,0, 177);
IPAddress gateway(192,168,0, 1);
IPAddress subnet(255, 255, 255, 0);
SoftwareSerial mySerial(7, 8); // RX, TX
SoftwareSerial XBee (6,5);
// telnet defaults to port 1001
EthernetServer server(1001);
boolean alreadyConnected = false; // whether or not the client was connected previously
char data=(char)0;
  XBee.begin(19200);
  // initialize the ethernet device
  Ethernet.begin(mac, ip, gateway, subnet);
  // start listening for clients
  server.begin();
  Serial.println("Initializing SD card...");
  Serial.println("Chat server address:");
  Serial.print(Ethernet.localIP());
if (!SD.begin(4)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  myFile = SD.open("TA.txt", FILE_WRITE);
  // wait for a new client:
  // when the client sends the first byte, say hello:
  if (client) {
    while(client.connected()){
    if (!alreadyConnected) {
      // clead out the input buffer:
      client.flush();
      Serial.println("Client Connected ");
      XBee.println("A301A");
      alreadyConnected = true;
    if (client.available() > 0) {
      // read the bytes incoming from the client:
      char thisChar = client.read();
      Serial.write(thisChar);
      XBee.println(thisChar);
      String stringOne = String (thisChar);
      myFile.print(stringOne);
    if (myFile) {
       myFile.println("Data :");
    if (Serial.available() > 0){
    char c=Serial.read();
    client.write(c);
    XBee.println(c);
    if(XBee.available()>0){
      char c=XBee.read();
      Serial.write(c);
      data=c;
      client.write(c);
    char stops= 120 ;
    if(data==stops){
    client.stop();
    data=(char)0;
    Serial.println("Client Disconected");
    client.stop();
  myFile.close();
  Serial.flush();
sorry for my english
What is this nonsense? You haven't even initialized the Serial instance.
Forget this. Get a Mega. You can NOT have two instances of SoftwareSerial listening at the same time. AND, you do NOT have a mySerial connected to those pins. Use a name that means something!
More useless crap.
You are sending binary data from the Serial Monitor application. Why are you sending binary data?
If one byte is available, it's a really dumb idea to read two bytes.
Send some nonsense to the client. What a great idea.
    client.print("&&");
The separator between name=value pairs is &, not &&.
    client.stop();
Without reading the server response? You just locked that socket out of use. Do this 4 times, sending ONE CHARACTER to a client, and your Ethernet shield is useless until the Arduino is rebooted.
You have our permission to.
Wrapping one character in a String instance is the ultimate in wastefulness. Knock that crap off.
There is nothing obvious about what the second code is doing. You seriously need to add some comments. Although I suspect that Ctrl-A, Ctrl-X would be a better use of your time.
PaulS, I'm going out on a limb here saying you've never had actual experience teaching. Why don't you actually try helping someone instead of treating them as if they are a complete idiot. Don't bring your negative attitude to the help forums. People aren't born with this knowledge.
sorry for my post.
ok i tell what i asking.
pauls : i delete if not uses
char inChar = Serial.read();//sorry this i try to get data first
i use arduino uno then i delete
the third one i only try
sorry not deleted this code
then i want get data from xbee
    char c = XBee.read();//this code if xbee read
i want change char c using string to post data to web
this my php
<?php
    // Connect to MySQL
    include("dbconnect.php");
    // Prepare the SQL statement
    $SQL = "INSERT INTO test.data (kelas ,data) VALUES ('".$_GET["kelas"]."', '".$_GET["data"]."')";
    // Execute SQL statement
    mysql_query($SQL);
    // Go to the review_data.php (optional)
    header("Location: review_data.php");
sorry for sdcard code
      myFile.print(stringOne);// this deleted too
sorry for that code. i want write string data from my android to arduino using wifi. then data write to sdcard. and then sdcard only write Ý not clear data. i write from my android 10000
@PaulS, Please, tone it down. There really is no need for that kind of language and attitude.
I won't ask again.
