Hello! First time here.
Im currently working on something where i needed to setup a WiFi communication between 2 ESP32. The host is sending his sensor's data to the other one.
I currently see the data on the URL i provided, which is great.
My problem is that i need to send back another data from the Client to the Host, but whenever i try to make a POST request, it just does nothing. The code still works, but if i got to the new URL i set up, an Error 500 appears.
This is my code (some variables and functions are in french, but don't mind them):
For the Host:
#ifndef LIBRARIES_ESP32SERVO_SRC_ESP32TONE_H_
#define LIBRARIES_ESP32SERVO_SRC_ESP32TONE_H_
#include "ESP32PWM.h"
void tone(int pin, unsigned int frequency);
void noTone(int pin);
#endif /* LIBRARIES_ESP32SERVO_SRC_ESP32TONE_H_ */
#include <NewPing.h>
#include "WiFi.h"
#include "ESPAsyncWebServer.h"
#include <Wire.h>
//Variables du WiFi
const char* ssid = "ESP32-Access-Point";
// Créer un AsyncWebServer objet sur le port 80
AsyncWebServer server(80);
//Variables pour les autres options
const int BROCHE_BTN_S = 13;
byte const BROCHE_DEL_S = 18;
int buzzer_S = 32;
int distance_S;
//Variables pour la moyenne
int valeurmax_S = 10;
int moyenne_S = 0;
int compteur = 0;
//Variables du délai pour le capteur
unsigned long previousMillisC = 0;
const long intervalC = 50;
//Variables pour le capteur
#define TRIGGER_PIN_S 26 //Broche Trigger du capteur
#define ECHO_PIN_S 25 //Broche Echo
#define MAX_DISTANCE 300 //Distance maximale pour le capteur voulue (cm). Maximum du capteur: 400-500cm
NewPing sonar_S(TRIGGER_PIN_S, ECHO_PIN_S, MAX_DISTANCE); //Déclaration des broches pour le NewPing
String valeur;
//Initialise les différentes options et leurs valeurs par défaut
pinMode(BROCHE_DEL_S, OUTPUT);
digitalWrite(BROCHE_DEL_S, LOW);
pinMode(buzzer_S, OUTPUT);
pinMode(BROCHE_BTN_S, INPUT);
// Mettre la carte ESP comme point d'accès
Serial.print("Setting AP (Access Point)…");
WiFi.softAP(ssid);
IPAddress IP = WiFi.softAPIP();
Serial.print("AP IP address: ");
Serial.println(IP);
server.on("/compteur", HTTP_GET, [](AsyncWebServerRequest * request) {
request->send_P(200, "text/plain", valeur.c_str());
bool status;
// Start server
server.begin();
unsigned long currentMillisC = millis();
if (currentMillisC - previousMillisC >= intervalC) {
//Détection du capteur
distance_S = sonar_S.ping_cm();
Serial.print("Ping: ");
Serial.print(distance_S); //Envoi le ping, obtient la distance en cm et affiche le résultat
Serial.println("cm");
Serial.println(compteur);
if (0 < distance_S && distance_S < (valeurmax_S - 10)) { //Si la détection se trouve à l'intérieur de la limite, buzzer et DEL s'activent et compteur incrémente
digitalWrite(BROCHE_DEL_S, HIGH);
tone(buzzer_S, 400);
noTone(buzzer_S);
compteur++;
valeur = String(compteur);
//Bouton sert à mettre valeur limite pour la détection
if (digitalRead(BROCHE_BTN_S) == LOW) {
Serial.println("BTN appuyé");
moyenne_S = 0;
for (int j = 0; j < 10; j++) {
moyenne_S = moyenne_S + distance_S;
valeurmax_S = moyenne_S / 10;
digitalWrite(BROCHE_BTN_S, HIGH);
compteur = 0;
previousMillisC = currentMillisC;
And for the Client:
#include <HTTPClient.h>
#include "Ecran.h"
#include <Wire.h>
#include <WiFi.h>
//Variables du WiFi
const int BROCHE_BTN_E = 13;
byte const BROCHE_DEL_E = 18;
int buzzer_E = 32;
int distance_E;
int valeurmax_E = 10;
int moyenne_E = 0;
int compteur = 0;
String compteurS;
//L'adresse URL utilisée
const char* serverNameComp = "http://192.168.4.1/compteur";
const char* serverNameFinal = "http://192.168.4.1/final";
//Variables du délai pour l'écran
unsigned long previousMillis = 0;
const long interval = 1000;
Ecran monEcran; //Création de l'objet 'ecran' de classe Ecran.
#define TRIGGER_PIN_E 26 //Broche Trigger du capteur
#define ECHO_PIN_E 25 //Broche Echo
NewPing sonar_E(TRIGGER_PIN_E, ECHO_PIN_E, MAX_DISTANCE); //Déclaration des broches pour le NewPing
String valeur;
//Variables de l'équation
int FinalE;
int FinalS;
int Final;
String Resultat;
pinMode(BROCHE_DEL_E, OUTPUT);
digitalWrite(BROCHE_DEL_E, LOW);
pinMode(buzzer_E, OUTPUT);
pinMode(BROCHE_BTN_E, INPUT);
//Initialiser l'écran.
monEcran.begin();
//Connexion au WiFi
WiFi.begin(ssid);
Serial.println("Connecting");
Serial.print(".");
Serial.println("");
Serial.print("Connected to WiFi network with IP Address: ");
Capteur();
if (currentMillis - previousMillis >= interval) {
//Vérifier le status de la connexion WiFi
if (WiFi.status() == WL_CONNECTED ) {
compteurS = httpGETRequest(serverNameComp);
Serial.println("Compteur: " + compteurS);
FinalE = valeur.toInt();
FinalS = compteurS.toInt();
Final = FinalE - FinalS;
if (Final <= 0) {
Final = 0;
Resultat = String(Final);
//Afficher sur l'écran
monEcran.effacer(); //Effacer tout l'écran
monEcran.display();
monEcran.ecrire("Il y a ", 0, 2);
monEcran.ecrire(Resultat, 2, 2);
monEcran.ecrire("personnes", 4, 2);
monEcran.display();
WiFiClient client;
HTTPClient http;
http.begin(client, serverNameFinal);
int httpResponseCode = http.POST(Resultat);
if (httpResponseCode > 0) {
String response = http.getString(); //Get the response to the request
Serial.println(httpResponseCode); //Print return code
Serial.println(response); //Print request answer
Serial.print("Error on sending POST: ");
http.end();
else {
Serial.println("WiFi Disconnected");
void Capteur() {
distance_E = sonar_E.ping_cm();
Serial.print(distance_E); //Envoi le ping, obtient la distance en cm et affiche le résultat
if (0 < distance_E && distance_E < (valeurmax_E - 10)) { //Si la détection se trouve à l'intérieur de la limite, buzzer et DEL s'activent et compteur incrémente
digitalWrite(BROCHE_DEL_E, HIGH);
tone(buzzer_E, 400);
noTone(buzzer_E);
compteur++;
if (digitalRead(BROCHE_BTN_E) == LOW) {
moyenne_E = 0;
for (int i = 0; i < 10; i++) {
moyenne_E = moyenne_E + distance_E;
valeurmax_E = moyenne_E / 10;
digitalWrite(BROCHE_BTN_E, HIGH);
compteur = 0;
Final = 0;
String httpGETRequest(const char* serverName) {
WiFiClient client;
HTTPClient http;
// Your Domain name with URL path or IP address with path
http.begin(client, serverName);
// Send HTTP POST request
int httpResponseCode = http.GET();
String payload = "--";
Serial.print("HTTP Response code: ");
payload = http.getString();
else {
Serial.print("Error code: ");
// Free resources
http.end();
return payload;
Hope anyone can help me with that
