Dunno ! haven' tried it
http://itp.nyu.edu/physcomp/sensors/Code/ArduinoXportMySQL
/* Arduino to Xport to PHP to MySQL
Arduino Code for interfacing directly to an XPORT for
posting to a MySQL database through a PHP script
Originally developed by Tom Igoe, Oct 2005
Translated from the Pic Basic by Jamie, Feb 2007
Tom's php script is also down below...
XPORT SETTINGS
*** Channel 1
Baudrate 9600, I/F Mode 4C, Flow 00
Port 10001
Remote IP Adr: --- none ---, Port 00000
Connect Mode : D4
Disconn Mode : 00
Flush Mode : 00
*** Expert
TCP Keepalive : 45s
ARP cache timeout: 600s
High CPU performance: disabled
Monitor Mode @ bootup : enabled
HTTP Port Number : 80
SMTP Port Number : 25
// define variables:
int adcVar = 0;
int inByte = 0;
int tcpPin = 13;
int connected = 0;
long measurementPeriod = 60000; //i.e.: ~60 seconds between measurements
// start serial port at 9600 bps:
// pause to let Xport boot up:
delay(2000);
blinkie(5, 100);
// if you're connected to the server, then
// make a HTTP call. If not, then connect
// to the server:
if (connected == 1)
// read sensors, convert to bytes:
adcVar = analogRead(0);
// send HTTP GET request for php script:
http_request();
// attempt to connect to the server:
xport_connect();
digitalWrite(tcpPin, connected);
// pause so we're not overwhelming the server:
delay(measurementPeriod/2);
//Serial.print("After 3 second delay in main loop");
void xport_connect()
// turn off LED to indicate HTTP GET is in progress:
digitalWrite(tcpPin, LOW);
//if (Serial.available() > 0) {
// get incoming byte:
inByte = Serial.read();
//Serial.print(inByte);
// wait for a "C" byte to come back:
while (inByte != 67)
//Serial.print("Waiting for xport to send back C");
Serial.print("C128.122.253.189/80");
Serial.print(10, BYTE);
delay(100);
connected = 1;
void http_request()
Serial.print("GET /~ja771/sensorworkshop/datalogger/sql_datalog.php?action=insert&");
Serial.print("sensorValue=");
Serial.print(adcVar,DEC);
Serial.print(" HTTP/1.1");
Serial.print("HOST: itp.nyu.edu");
//we should really be waiting for the return '0' here
//from the script, but it just never seemed to come,
//hanging the program in a while loop like the one above
//so instead we just delay until the Xport lets go of it's connection
//and then we try again
connected = 0;
void blinkie(int number, int speed)
int i;
for (i=0; i<number; i++)
digitalWrite(tcpPin, HIGH);
delay(speed);
delay(speed);
//THE PHP SCRIPT USED WITH THIS EXAMPLE IS BELOW//
<?php
// get username & pwd info:
include "secret.php";
// initialize variables:
$sensorValue = -1; // value from the sensor
$date = -1; // date string: YYYY-MM-DD
$time = -1; // time string: HH:mm:ss in 24-hour clock
$recordNumber = -1; // which record to delete
$list = 0; // whether or not to list results in HTML format
$databaseName = 'ja771';
$tableName = 'datalogger';
// open the database:
$link = open_database('localhost', $databaseName, $username, $password);
// process all the HTTP GET variables:
while(list($key, $value) = each($HTTP_GET_VARS))
// action is the SQL action: insert, delete, select, etc.
if ($key == "action") {
$action = $value;
// sensorValue is the result from the remote sensor system
if ($key == "sensorValue") {
$sensorValue = $value;
// date that the sensor reading was taken
if ($key == "date") {
$date = $value;
// time that the sensor reading was taken
if ($key == "time") {
$time = $value;
// database record number (for deleting only):
if ($key == "recNum") {
$recordNumber = $value;
// whether or not to print out results in HTML:
if ($key == "list") {
$list = $value;
// insert a new record in the database:
if ($action == "insert") {
// make sure date and time have values:
if ($date == -1 || $time == -1) {
// if not values, generate them from the server time
// (I should probably properly check for valid date and time strings here):
list($date, $time) = split(" ", date("Y-m-d H:i:s"));
// Only insert if we got a sensor value from the GET:
if (sensorValue != -1) {
insert_record($tableName, $sensorValue, $date, $time);
// if we're supposed to delete, delete:
if ($action == "delete") {
// only delete if we got a record number from the GET:
if ($recordNumber != -1) {
delete_record($tableName, $recordNumber);
// if we should list in HTML format, list the whole table:
if ($list == 1) {
echo "<html><head></head><body>";
// browse the whole table:
browse_table($tableName);
echo "</body></html>";
// close the database:
close_database($link);
// end with a 0 to close the session to the client:
echo "\0";
end;
// Functions -------------------------------
// Connect to a server and open a database:
function open_database($myServer, $myDatabase, $myUser, $myPwd) {
$myLink = mysql_connect($myServer, $myUser, $myPwd)
or die('Could not connect: ' . mysql_error());
if ($list == 1) {
echo 'Connected successfully';
mysql_select_db($myDatabase) or die('Could not select database');
return $myLink;
// close an open database:
function close_database($myLink) {
mysql_close($myLink);
// select all from a table:
function browse_table($myTable) {
$query = "SELECT * FROM `$myTable`";
$result = mysql_query($query) or die('Query failed: ' . mysql_error());
// Printing results in HTML
echo "<table>\n";
while ($line = mysql_fetch_array($result, MYSQL_ASSOC)) {
echo "\t<tr>\n"; //
foreach ($line as $col_value) {
echo "\t\t<td>$col_value</td>\n";
echo "\t</tr>\n";
echo "</table>\n";
// Free resultset
mysql_free_result($result);
// insert a new record in the table:
function insert_record($myTable, $recValue, $recDate, $recTime) {
$query = "INSERT INTO `$myTable` (`Value`, `Date`, `Timestamp`) VALUES ('$recValue', '$recDate','$recTime')";
// Free resultset
// delete a record from the table:
function delete_record($myTable, $recNum) {
$query = "DELETE FROM `$myTable` WHERE `ID` = $recNum LIMIT 1";
// Free resultset
