To send data to another server you also need client code. Below is code with both server and client functions.
//zoomkat 7-03-12, combined client and server
//simple button GET with iframe code
//for use with IDE 1.0
//open serial monitor and send an g to test client and
//see what the arduino client/server receives
//web page buttons make pins high/low
//use the ' in html instead of " to prevent having to escape the "
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //assign arduino mac address
byte ip[] = {192, 168, 1, 102 }; // ip in lan assigned to arduino
byte gateway[] = {192, 168, 1, 1 }; // internet access via router
byte subnet[] = {255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port arduino server will use
EthernetClient client;
char serverName[] = "web.comporium.net"; // (DNS) zoomkat's test web page server
//byte serverName[] = { 208, 104, 2, 86 }; // (IP) zoomkat web page server IP address
String readString; //used by server to capture GET request
void setup(){
pinMode(5, OUTPUT); //pin selected to control
pinMode(6, OUTPUT); //pin selected to control
pinMode(7, OUTPUT); //pin selected to control
pinMode(8, OUTPUT); //pin selected to control
//pinMode(5, OUTPUT); //pin 5 selected to control
Ethernet.begin(mac,ip,gateway,gateway,subnet);
server.begin();
Serial.println(F("server/client 1.0 test 7/03/12")); // keep track of what is loaded
Serial.println(F("Send an g in serial monitor to test client")); // what to do to test client
void loop(){
// check for serial input
if (Serial.available() > 0)
byte inChar;
inChar = Serial.read();
if(inChar == 'g')
sendGET(); // call client sendGET function
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
//Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
Serial.print(readString); //print to serial monitor for debuging
//now output HTML data header
if(readString.indexOf('?') >=0) { //don't send new page
client.println(F("HTTP/1.1 204 Zoomkat"));
client.println();
client.println();
else {
client.println(F("HTTP/1.1 200 OK")); //send new page on browser request
client.println(F("Content-Type: text/html"));
client.println();
client.println(F("<HTML>"));
client.println(F("<HEAD>"));
client.println(F("<TITLE>Arduino GET test page</TITLE>"));
client.println(F("</HEAD>"));
client.println(F("<BODY>"));
client.println(F("<H1>Zoomkat's simple Arduino 1.0 button</H1>"));
// DIY buttons
client.println(F("Pin5"));
client.println(F("<a href=/?on2 target=inlineframe>ON</a>"));
client.println(F("<a href=/?off3 target=inlineframe>OFF</a>
client.println(F("Pin6"));
client.println(F("<a href=/?on4 target=inlineframe>ON</a>"));
client.println(F("<a href=/?off5 target=inlineframe>OFF</a>
client.println(F("Pin7"));
client.println(F("<a href=/?on6 target=inlineframe>ON</a>"));
client.println(F("<a href=/?off7 target=inlineframe>OFF</a>
client.println(F("Pin8"));
client.println(F("<a href=/?on8 target=inlineframe>ON</a>"));
client.println(F("<a href=/?off9 target=inlineframe>OFF</a>
client.println(F("Pins"));
client.println(F(" <a href=/?off2468 target=inlineframe>ALL ON</a>"));
client.println(F(" <a href=/?off3579 target=inlineframe>ALL OFF</a>"));
client.println(F("<IFRAME name=inlineframe style='display:none'>"));
client.println(F("</IFRAME>"));
client.println(F("</BODY>"));
client.println(F("</HTML>"));
delay(1);
//stopping client
client.stop();
///////////////////// control arduino pin
if(readString.indexOf('2') >0)//checks for 2
digitalWrite(5, HIGH); // set pin 5 high
Serial.println(F("Led 5 On"));
Serial.println();
if(readString.indexOf('3') >0)//checks for 3
digitalWrite(5, LOW); // set pin 5 low
Serial.println(F("Led 5 Off"));
Serial.println();
if(readString.indexOf('4') >0)//checks for 4
digitalWrite(6, HIGH); // set pin 6 high
Serial.println(F("Led 6 On"));
Serial.println();
if(readString.indexOf('5') >0)//checks for 5
digitalWrite(6, LOW); // set pin 6 low
Serial.println(F("Led 6 Off"));
Serial.println();
if(readString.indexOf('6') >0)//checks for 6
digitalWrite(7, HIGH); // set pin 7 high
Serial.println(F("Led 7 On"));
Serial.println();
if(readString.indexOf('7') >0)//checks for 7
digitalWrite(7, LOW); // set pin 7 low
Serial.println(F("Led 7 Off"));
Serial.println();
if(readString.indexOf('8') >0)//checks for 8
digitalWrite(8, HIGH); // set pin 8 high
Serial.println(F("Led 8 On"));
Serial.println();
if(readString.indexOf('9') >0)//checks for 9
digitalWrite(8, LOW); // set pin 8 low
Serial.println(F("Led 8 Off"));
Serial.println();
//clearing string for next read
readString="";
void sendGET() //client function to send and receive GET data from external server.
if (client.connect(serverName, 80)) {
Serial.println(F("connected"));
client.println(F("GET /~shb/arduino.txt HTTP/1.1"));
client.println(F("Host: web.comporium.net"));
client.println(F("Connection: close"));
client.println();
else {
Serial.println(F("connection failed"));
Serial.println();
while(client.connected() && !client.available()) delay(1); //waits for data
while (client.connected() || client.available()) { //connected or data available
Serial.print(c);
Serial.println();
Serial.println(F("disconnecting."));
Serial.println(F("=================="));
Serial.println();
client.stop();
