Send data to SQL Database
Hello Community
I really need some help. I have a Arduino set up that read temperature from the classroom. It prints it to the LCD display on the Arduino board.
I have followed some tutorials from google searching but cannot find any solutions
I have this file already uploaded to my website and have attached it to this post. In addition I have also added my Arduino code which prints data to LCD display
How can I send the data to the DB using just the WiFi Shield and not ethernet as I do not have the Ethernet components
PHP file that is stored on my Website
<?php // Prepare variables for database connection $dbusername = "MyDBName"; // enter database username, I used "arduino" in step 2.2 $dbpassword = "MyPassword"; // enter database password, I used "arduinotest" in step 2.2 $server = "MyServer"; // IMPORTANT: if you are using XAMPP enter "localhost", but if you have an online website enter its address, ie."www.yourwebsite.com" // Connect to your database $dbconnect = mysql_pconnect($server, $dbusername, $dbpassword); $dbselect = mysql_select_db("SMK23080_webdevelopme",$dbconnect); // Prepare the SQL statement $sql = "INSERT INTO temperature (m_id, m_admin, temperature, m_time) VALUES ('".$_GET["m_id"]."',, '".$_GET["m_admin"]."', '".$_GET["temperature"]."', '".$_GET["m_time"]."')"; // Execute SQL statement mysql_query($sql); ?>
Thanks guys very much
arduionCode.txt (3.36 KB)
It might be stored on your web SERVER. It is not stored on your web SITE.
You make a GET request. The fact that you have a WiFi shield, instead of an Ethernet shield, is irrelevant. How the data gets to the router (wirelessly or over a CAT5 cable) makes no difference.
But before you event start on the Arduino side, first check that you are able to upload data to your webserver by issuing a command of the following example format in a web browser of a PC (or other device) which has network connectivity to your web server:
http://192.168.1.99/sample.php?m_id=23&m_admin=34&temperature=45&m_time=56
or maybe on the server it self, if that is available to you.
Then you are sure of your php/mySql configuration and you've got some basis for your http GET statement.
Incidentally, your SQL query seems to have two consecutive comma characters in it.
