Hello everyone!
I use the Twitter library that supports OAuth Arduino Playground - Twitter Library and i want to post the values from a temperature sensor along with some additional text, in the same tweet.
As such, a tweet should contain a static text as well as the dynamic temperature value taken from the temp sensor.
So here is my question:
How can i concatenate a static text with a dynamic value in order to send the entire string via a single tweet ?
I test the following code taken from the Twitter library page:
/* Post a simple message to Twitter */
#include <Ethernet.h>
#include <Twitter.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 10, 0, 0, 177 };
byte gateway[] = { 10, 0, 0, 1 };
byte subnet[] = { 255, 255, 0, 0 };
Twitter twitter("YOUR-TOKEN");
char msg[] = "Hello, World! I'm Arduino!";
Ethernet.begin(mac, ip, gateway, subnet);
Serial.println("connecting ...");
if (twitter.post(msg)) {
int status = twitter.wait();
if (status == 200) {
Serial.println("OK.");
Serial.print("failed : code ");
Serial.println(status);
Serial.println("connection failed.");
In the example code above, the string array variable contains a static string
The "post" function of the twitter library twitter.post(msg)
expects a const char *message variable.
What do i need to do to concatenate a static text and a dynamic value ?
Any help to the right direction is much appreciated!
John
