Send file from sd card to server
Hi i have esp8266 nodemcu, and sd card reader. I need send a file from sd card to server. How to do it?
i found code but it doesn’t work.
here code.
    WiFiClient client;
if (client.connect("server ip", 80)) {
File file = SD.open("test.csv");
client.println(F("POST /http://example.com/...../examplefolder/ HTTP/1.1 "));
client.print(F("Host: "));
client.println("server ip");
client.println(F("Connection: close"));
client.print(F("Content-Length: "));
client.println(file.size());
client.println();
while (file.available()) {
client.write(file.read());
file.close();
client.stop();
i found code but it doesn't work.
here code.
WiFiClient client;
client.println();
file.close();
client.stop();
Define "it doesn't work".
Please post your complete code. Where did you find it? What have you tried already? Do you understand the code you're using, or did you just blindly copy-paste it?
Pieter
Edit: Do not cross-post!
Rubbish. The protocol (http://) and server are NOT part of the POST command.
How to do it?
Just like that, if you want it to take forever.
Both the read() and write() methods are overloaded to use array, resulting in many fewer packets, and much faster sending.
esp8266 can do client.write(file)
did you see the WiFiClient example?
Cross-posted @ http://forum.arduino.cc/index.php?topic=556337.msg3793750#msg3793750
@OP, don't do that, you're wasting everybody's time.
Threads merged.
Hi, again, i am so sorry for Cross-post, but i really need help about this.
I just don’t know how to send from sd card file, to server.
and when i do this…
client.write(file) -->Error compiling for board NodeMCU 1.0 (ESP-12E Module).
If you have some examples, please tell me what code i need to send from sd card to server a file.
hunter360:
and when i do this...
sorry, it works only with SPIFFS file, not with SD file
the file upload is done with POST request. do not forget to set the Content-length header
WiFiClient client;
  if (client.connect(yourHost, 80)) {
    File dataFile = SD.open("filename.csv");
    client.println(F("POST /your-url HTTP/1.1"));
    client.println(yourHost);
    client.println(dataFile.size());
    client.println();
    while (dataFile.available()) {
        client.write(dataFile.read());
    dataFile.close();
    client.stop();
warning, this will be slow. if it works, we can add buffering
  #include <ESP8266WiFi.h>
      #include <ESP8266WiFiMulti.h>
      #include <ESP8266HTTPClient.h>
#include <SPI.h>
#include <SD.h>
 ESP8266WiFiMulti WiFiMulti;
File myFile;
  WiFiMulti.addAP("ssid", "password");
        WiFiMulti.addAP("ssid2", "password2");
     Serial.println("Connecting ...");
  int i = 0;
  (WiFiMulti.run() != WL_CONNECTED) ; // Wait for the Wi-Fi to connect: scan for Wi-Fi networks, and connect to the strongest of the networks above
      Serial.println('\n');
  Serial.print("Connected to ");
  Serial.println(WiFi.SSID());              // Tell us what network we're connected to
  Serial.print("IP address:\t");
  while (!Serial) {
  Serial.print("Initializing SD card...");
  if (!SD.begin(4)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  myFile = SD.open("test.txt", FILE_WRITE);
  if (myFile) {
    Serial.print("Writing to test.txt...");
    myFile.println("testing 1, 2, 3.");
    myFile.close();
    Serial.println("done.");
    Serial.println("error opening test.txt");
//in 00.00.000.00 is my servers ip, and in example is my url
  WiFiClient client;
  if (client.connect("00.00.000.00", 80)) {
    File myfile = SD.open("test.txt");
    client.println(F("POST /http://example.com/folder HTTP/1.1"));
    client.println("00.00.000.00");
    client.println(myfile.size());
    client.println();
    while (myfile.available()) {
        client.write(myfile.read());
    myfile.close();
    client.stop();
        WiFiMulti.addAP("ssid2", "password");
  int i = 0;
  while (!Serial) {
code works, but nothing appears in server directory.
the host and port should not be in url after POST
client.println(F("POST /folder HTTP/1.1"));
Still nothing with changes... client.println(F("POST /folder HTTP/1.1"));
but have question, is there other way to send to server? file from sd card?
Have you tried flushing before stopping the client?
yes
Where?
how large is the file? test with a small file.
it it's small file. Only create test 1 2 3 , and nothing else.
use IPAddress in connect and in Host header
IPAddress serverIP(123, 456, 78, 9);
if (client.connect(serverIP, 80)) {
client.println(serverIP);
nop, didn't work. :frowning:
Time to open up Wireshark then.
