send files
hey everyone , i want to send a file from Arduino to the server or other Arduino
i wrote a code that's open the file then write the content of the text on an array and then send it
that would work if the data is small, but when i try to send, .wav it will takes lots of time if i do it that why ( storing each byte in array )
i want to send the whole file at on time
is there a way or a library helps ?
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <SD.h>
const int push1 = 2;
File myFile;
char a[400];
int c= 0;
// network parameters
byte mac[] = { 0x90, 0xA2, 0xDA, 0x0E, 0x05, 0x02 };  // ethernet interface MAC address
IPAddress localIp(10,131,41,72);    // local ip address
IPAddress destIp(10,131,41,74);      // destination ip address
unsigned int port = 9631;               // destination port
// EthernetUDP to send and receive messages.
EthernetUDP Udp;
// timing
// setup the arduino and shields
    pinMode(push1, INPUT);
  //Initialize serial and wait for port to open:
  Serial.begin(9600); // 19200
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.print("Initializing SD card...");
  if (!SD.begin(4)) {
    Serial.println("initialization failed!");
    while (1);
  Serial.println("initialization done.");
  // start ethernet and udp
  Ethernet.begin(mac, localIp);   // static ip version
  //if(Ethernet.begin(mac) == 0) {     // dhcp version
  // report failure to obtain network parameters
  // Serial.println("DHCP error");
  // no point in carrying on, loop indefinitely:
  // while(true)
  // open UDP port
  Udp.begin(port);
  // show the local ip address (useful for dhcp)
  Serial.print("Local IP: ");
  Serial.println(Ethernet.localIP());
  // initialize previous millis variables
// do tasks
if(digitalRead(push1) == LOW){
   myFile = SD.open("R.wav" , FILE_READ);
  if (myFile) {
    // read from the file until there's nothing else in it:
    Serial.println("i will send now");
    while (myFile.available()) {
        a[i] = myFile.read();
        i++;
      Udp.beginPacket(destIp, port);
     Udp.write(a);
      Udp.endPacket();
      Serial.println("Sending UDP message");
    // close the file:
    myFile.close();
   // if the file didn't open, print an error:
    Serial.println("error opening test.txt");
