i need to send a float value over i2c, from one Arduino to another.
i understand i need to convert it, because onle byte or string can be sent.
so i converted it to string, but a get an error when sending, that says
" no matching function for call to 'TwoWire::write(String&)' "
the code looks like this (reading a temperature from a Dht22 on one arduino, sending it to another for display on a screen):
float t = dht.readTemperature()-1.5; // reading the temp from sensor
String temp = String(t,1); // conversing to string
Serial.println(temp); //check if conversion is ok
Wire.beginTransmission(8);
Wire.write(temp); // my error is here.
Wire.endTransmission();
any sugestions? should i convert to something else ? and how?
ps: i will see about receving on the oder side after this works :))
cand i send it without converting? as a parameter to the wire.write function?
if i use
// String temp = String(t,1); // conversing to string
// Serial.println(temp); //check if conversion is ok
byte* px = (byte*)&t;
Serial.println(*px); //i get returns as 51, 102, or sometimes 0
Wire.write(*px); // my error is here.
String temp = String(t,1); // converting to string
Wire.write(temp[4]);
it works now.
Wire.write(temp[4]); this is the right sintax, it sends the right value.
