Send http request from Arduino using ENC28J60 chip
Any one help me
We are trying to call http request-Response from etherCard library :
Http request URL is http://172.16.0.22/qmsWebApi/api/values
so we are not response from server
#include <EtherCard.h>
// ethernet interface mac address, must be unique on the LAN
static byte mymac = { 0x74,0x69,0x69,0x2D,0x30,0x31 };
static byte myip = { 172,16,0,35 };
static byte gwip = { 172,16,0,1 };
byte Ethernet::buffer[700];
static uint32_t timer;
const char website PROGMEM = “172.16.0.22”;
// called when the client request is complete
static void my_callback (byte status, word off, word len) {
Serial.println(">>>");
Ethernet::buffer[off+300] = 0;
Serial.print((const char*) Ethernet::buffer + off);
Serial.println("…");
void setup () {
Serial.begin(57600);
Serial.println(F("\n[webClient]"));
if (ether.begin(sizeof Ethernet::buffer, mymac) == 0)
Serial.println(F(“Failed to access Ethernet controller”));
ether.staticSetup(myip, gwip);
ether.printIp("IP: ", ether.myip);
ether.printIp("GW: ", ether.gwip);
// if website is a string containing an IP address instead of a domain name,
// then use it directly. Note: the string can not be in PROGMEM.
char websiteIP = “172.16.0.22”;
ether.parseIp(ether.hisip, websiteIP);
ether.printIp("SRV: ", ether.hisip);
Serial.print("<<< REQ “);
ether.browseUrl(PSTR(”/qmsWebApi/api/values/"), “”, website, my_callback);
void loop () {
word pos =ether.packetLoop(ether.packetReceive());
if(pos)
Serial.println(">>> Success ");
if (millis() > timer) {
timer = millis() + 5000;
