Send http
Hi, pretty new to arduino and have a need to send the following http to a local address on my network.
Is this possible and if so could you give me a bit of guidance ?
Thanks is advance.
Simon
http://ip_address:3480/data_request?id=action&output_format=xml&DeviceNum=6&serviceId=urn:upnp-org:serviceId:SwitchPower1&action=SetTarget&newTargetValue=0
(deleted)
That does not make sense. You can send requests, as a client, or you can respond to requests, as a server.
It looks like you want to act as a client, and make a GET request. Look at the client example.
Thanks for the replies.
I'm not sure really.
All I know is if I send that http command it will issue a command on my home controller (Vera). If I try it in Chrome it does work and It does respond "ok" when it receives it.
Is this possible in arduino ?
At the minute I use an arduino to receive a serial command from an rti remote and send a UDP command to my lightwaverf lighting controller. I'd like to remove the lighting controller and send directly to the Vera.
Thanks.
You do NOT send http commands. The httpd daemon parses the URL and makes a GET request.
Yes. Look at the client example.
