Hi there. In my project I need to perform machine learning on the accelerometer and gyroscope values to determine whether a person did fall down or not. I used arduino nano 33 ble to perform such function, right now i am having issues while trying to do the data collection. I planned to send the gyroscope and accelerometer values to my PC via BLE. I am using python Bleak in my PC as the client and arduino nano 33 ble as the server. In my code, I am sending total 504 bytes of data through BLE by using array and struct method. On my PC side, my Bleak python code are receiving data and the data are well converted into float values, but it takes like 1.5seconds to receive a whole 504 bytes of data. I want to ask is this the correct way to send huge bytes of data through BLE? Through my research BLE is meant to send packet with smaller size, so this cause me to have some concern, and the delay on the Bleak python side. The gyroscope and accelerometer are also set to output data rate of around 119Hz, but on my PC only receive one 504 bytes of packet in around 1.5s. Is there any way to transfer the accelerometer and gyroscope values on arduino nano 33 ble resulting in more efficient and lesser data loss? Apologize if the sentences are not well structed as English is not my first language. Below is my code. Thank you.
#include <Arduino.h>
#include <Wire.h>
#include <ArduinoBLE.h>
#include <Arduino_LSM9DS1.h>
// BLE UUIDs
#define BLE_UUID_SENSOR_DATA_SERVICE "2BEEF31A-B10D-271C-C9EA-35D865C1F48A"
#define BLE_UUID_MULTI_SENSOR_DATA "4664E7A1-5A13-BFFF-4636-7D0A4B16496C"
#define NUMBER_OF_SENSORS 126
union multi_sensor_data
struct __attribute__( ( packed ) )
float values[NUMBER_OF_SENSORS];
signed char bytes[ NUMBER_OF_SENSORS * sizeof( float ) ];
union multi_sensor_data multiSensorData;
// BLE
BLEService sensorDataService( BLE_UUID_SENSOR_DATA_SERVICE );
BLECharacteristic multiSensorDataCharacteristic( BLE_UUID_MULTI_SENSOR_DATA, BLERead | BLENotify, sizeof multiSensorData.bytes );
// const int BLE_LED_PIN = LED_BUILTIN;
// const int RSSI_LED_PIN = LED_PWR;
bool setupBleMode()
if ( !BLE.begin() )
return false;
// set advertised local name and service UUID:
BLE.setDeviceName( "Arduino Nano 33 BLE" );
BLE.setLocalName( "Arduino Nano 33 BLE" );
BLE.setAdvertisedService( sensorDataService );
// BLE add characteristics
sensorDataService.addCharacteristic( multiSensorDataCharacteristic );
// sensorDataService.addCharacteristic( allowCharacteristics );
// add service
BLE.addService( sensorDataService );
// start advertising
BLE.advertise();
return true;
Serial.begin( 115200 );
// while ( !Serial );
pinMode(LED_BUILTIN,OUTPUT);
if ( setupBleMode() )
// digitalWrite( BLE_LED_PIN, HIGH );
if (!IMU.begin()) {
Serial.println("Failed to initialize IMU!");
while (1);
IMU.setAccelFS(3);
IMU.setAccelODR(3);
IMU.setGyroOffset (0, 0, 0); // = uncalibrated
IMU.setGyroSlope (1, 1, 1); // = uncalibrated
IMU.setAccelFS(3);
IMU.setAccelODR(3); //
IMU.setAccelOffset(0, 0, 0); // uncalibrated
IMU.setAccelSlope (1, 1, 1); // uncalibrated
IMU.gyroUnit= DEGREEPERSECOND; // DEGREEPERSECOND RADIANSPERSECOND REVSPERMINUTE REVSPERSECOND
Serial.println("Gyroscope in degrees/second \n");
Serial.print("Gyroscope Full Scale = ±");
Serial.print(IMU.getGyroFS());
Serial.println ("°/s");
Serial.print("Gyroscope sample rate = ");
Serial.print(IMU.getGyroODR()); //alias IMU.gyroscopeSampleRate());
Serial.println(" Hz");
Serial.println("Accelerometer in degrees/second \n");
Serial.print("Accelerometer Full Scale = ±");
Serial.print(IMU.getAccelFS());
Serial.print("Accelerometer sample rate = ");
Serial.print(IMU.getAccelODR()); //alias IMU.gyroscopeSampleRate());
delay(4000);
BLEDevice central = BLE.central();
if ( central )
Serial.println( central.address() );
digitalWrite( LED_BUILTIN, HIGH ); //Turn on peripheral LED to indicate valid connection with Central Device
while ( central.connected() )
float gX, gY, gZ, aX, aY, aZ;
for(int i=0;i<=120;i+=6){
if(IMU.gyroAvailable() && IMU.accelAvailable()){
IMU.readGyro(gX,gY,gZ);
IMU.readAccel(aX,aY,aZ);
Serial.print(aX, 3);
Serial.print(',');
Serial.print(aY, 3);
Serial.print(',');
Serial.print(aZ, 3);
Serial.print(',');
Serial.print(gX, 3);
Serial.print(',');
Serial.print(gY, 3);
Serial.print(',');
Serial.print(gZ, 3);
multiSensorData.values[i]=aX;
multiSensorData.values[i+1]=aY;
multiSensorData.values[i+2]=aZ;
multiSensorData.values[i+3]=gX;
multiSensorData.values[i+4]=gY;
multiSensorData.values[i+5]=gZ;
multiSensorDataCharacteristic.writeValue( multiSensorData.bytes, sizeof multiSensorData.bytes );
digitalWrite( LED_BUILTIN, LOW );
