Send Information only once (Simple print)
I would like to show the status of my reed-contacts (PIN 5 and PIN 6) on a website. But unfortunatly if i plug the reed-contact i get the button (that should be green,yellow or red) 100 times instead of only 1 time. I cant find a command to show the status only once. How can i repair my skript that it only show the information once.
I know that the while command is the reason but i dont know what to use else...
I am new to Arduino programming and i would be glad if you could help me.
This is my main problem:
            while (digitalRead(Window_Bot_Pin))
              digitalWrite(Window_Led_Pin1, HIGH);
              client.println("<svg xmlns=http://www.w3.org/2000/svg version=1.1>");
              client.println("<circle cx=100 cy=50 r=30 stroke=black strok-width=2 fill=yellow />");
              client.println("</svg>");
            if(!digitalRead(Window_Top_Pin))
              digitalWrite(Window_Led_Pin1, LOW);
            while (digitalRead(Window_Top_Pin))
              digitalWrite(Window_Led_Pin2, HIGH);
              client.println("<circle cx=100 cy=50 r=30 stroke=black strok-width=2 fill=green />");
            if(!digitalRead(Window_Bot_Pin))
              digitalWrite(Window_Led_Pin2, LOW);
              client.println("<circle cx=100 cy=50 r=30 stroke=black strok-width=2 fill=red />");
Here the whole code:
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(10, 14, 5, 234);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
int Window_Led_Pin1 = 13;
int Window_Led_Pin2 = 12;
int Window_Top_Pin = 6;
int Window_Bot_Pin = 5;
int Status = 0;
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  pinMode(Window_Led_Pin1, OUTPUT);
  pinMode(Window_Led_Pin2, OUTPUT);
  pinMode(Window_Top_Pin, INPUT);
  pinMode(Window_Bot_Pin, INPUT);
  // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip);
  server.begin();
  Serial.print("server is at ");
  Serial.println(Ethernet.localIP());
  // listen for incoming clients
  if (client) {
    Serial.println("new client");
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial.write(c);
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          client.println("Content-Type: text/html");
          client.println("Connection: close");  // the connection will be closed after completion of the response
	  client.println("Refresh: 5");  // refresh the page automatically every 5 sec
          client.println();
          client.println("<!DOCTYPE HTML>");
          client.println("<html>");
          client.println("<head>");
          client.println("<title>");
          client.print("Fenstersensor");
          client.println("</title>");
          client.println("</head>");
          client.println("<h1>");
          client.println("Fenstersensor");
          client.println("</h1>");
          client.println("Window");
          // output the value of each analog input pin
          client.println("</html>");
        if (c == '\n') {
          // you're starting a new line
        else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
    Serial.println("client disonnected");
I have not looked in detail but the problem would seem to be that you have code repeated while a contact is made. No wonder you get multiple outputs.
You need to check that the contact state has changed since the previous time it was tested and that it is now HIGH. Have a look at the StateChangeDetection example in the Digital section of the IDE examples.
Thank you very much ! Now it works !
int buttonState = 0;
int buttonState2 = 0;
int lastButtonState2 = 0;
int lastButtonState = 0;
  buttonState = digitalRead(Window_Bot_Pin);
  buttonState2 = digitalRead(Window_Top_Pin);
  if (buttonState != lastButtonState) {
    if (buttonState == HIGH) {
      Serial.println("Fenster ist gekippt");
  else {
  Serial.println("Fenster ist offen");
  if (buttonState2 != lastButtonState2) {
    if (buttonState2 == HIGH) {
      Serial.println("Fenster ist geschlossen");
  else {
  lastButtonState = buttonState;
  lastButtonState2 = buttonState2;
