hi all.
i just a beginner hobbyist with Arduino. or i used to play with it the last 2 years. no programming experice.
but i tried to send a Unsigned Int thru I2C.
i have seen many differnt examples on the interweb, i also tried I2C_anthing. but i never understead it. ot got it working.
now i made my own Code that seems realy easy and i wonder why i never seen it before, or maby you can tell me if its good or whats wrong about it. but in the end it seems to work Perfect at my side.
so the quation is why did i not see this realy EASY!! code before.
Master
#include <Wire.h>
unsigned int Var = 1;
unsigned int lastVar = 0;
byte A;
byte B;
void setup(){
Wire.begin();
Var++;
if (Var != lastVar) {
A = Var % 256; //Repeat 256 (16bit)
B = Var / 256; // divide 65536 by 256 (8bit)
Wire.beginTransmission(1);
Wire.write("a");
Wire.write(A);
Wire.endTransmission();
Wire.write("b");
Wire.write(B);
lastVar = Var;
Slave
#include <Wire.h>
byte a;
byte b;
unsigned int Var;
void setup(){
Wire.begin(1);
Wire.onReceive(receiveEvent);
void loop(){
void receiveEvent(int howMany)
if(Wire.available()){
char z = Wire.read();
Serial.print(z);
if(z == 'a'){
a = Wire.read();
Serial.println(a);
if(z == 'b'){
b = Wire.read();
Serial.println(b);
Var= a + (b * 256); // put the 8 bit and 16 bit numbers together to get the Unsiged Int again.
Serial.println(Var);
