I have put this code in an arduino mega 2560 with a module a6 gsm connected in serial1. I have put the internal LED as control, the led turns on but does not execute the functions sendMSM() and makeCall() .
any ideas?
String input;
const byte Led = 13;
String telefono;
String mensajesms;
int longitudmensaje;
pinMode(Led, OUTPUT);
Serial1.begin(9600);
// delay(500);
while (Serial.available())
char character = Serial.read();
input.concat(character);
delay(10);
if (input.endsWith("%")== true){
telefono=(input.substring(0,10));
longitudmensaje=(input.length());
mensajesms=(input.substring(11,longitudmensaje));
sendMSM();
delay(7000);
makeCall();
digitalWrite(Led, HIGH);
input="";
void sendMSM() {
digitalWrite(Led, LOW);
Serial1.println("AT+CMGF=1");
delay(2000);
Serial1.print("AT+CMGS=\"");
Serial1.print(telefono);
Serial1.print(char(34)); // "
Serial1.print(char(13)); // CR
Serial1.print('\r'); // hex equivalent of newline
delay(2000);
Serial1.print(mensajesms);
Serial1.println (char(26)); //ctrl_z
void makeCall() {
// delay(10000);
// Serial1.println("AT");
// delay(1000);
Serial1.print("ATD");
Serial1.println(telefono);
delay(20000);
Serial1.println("ATH");
the message is sent from a program made in delphi using the main serial port of the arduino that is connected by usb.
The led turns on, so I understand that the verification is fine.
If I use this code to test the functions, everything works fine.
I really have no idea what might be happening.
char phone_no[]="8293353345";
char caracter;
String comando;
delay(300);
delay(2000);
Serial1.print(phone_no);
Serial1.write(0x22);
Serial1.write(0x0D); // hex equivalent of Carraige return
Serial1.write(0x0A); // hex equivalent of newline
delay(2000);
Serial1.print("GSM A6 test message!");
Serial1.println (char(26));//the ASCII code of the ctrl+z is 26
delay(10000);
Serial1.println(phone_no);
//Serial.println(";");
delay(20000);
