Send midi control change
Hi everybody
I’m new here i try to send a CC message and nothing happens
#include <MIDI.h>
MIDI_CREATE_DEFAULT_INSTANCE();
// read potentiometer value
//int analogValue = 0;
// maximum MIDI value is 127, first/previous potentiometer
// move has to always be different than previous value
int AnalogValue = 0; // define variables for the controller data
int lastAnalogValue = 128;
   Serial.begin(31250);
    MIDI.begin (MIDI_CHANNEL_OMNI);                      // Launch MIDI and listen to channel omni
        // Analog potentiometer
  // potentiometer gives values up to 1023
  // we need values not bigger than 127
  int analogValue = analogRead(A0)/8;
  // potentiometer could be too sensitive and
  // give different (+-1) values.
  // send CC only when the difference between last value
  // is more than 1
  if ((analogValue-lastAnalogValue) > 1 || (analogValue-lastAnalogValue) < -1)
    // value changed?
    if (analogValue != lastAnalogValue) {
      // send serial value (ControlNumber 1, ControlValue = analogValue, Channel 1)
      // more info: http://arduinomidilib.sourceforge.net/a00001.html
      MIDI.sendControlChange(12, analogValue, 1);
      lastAnalogValue = analogValue;
MIDI-OX moves when i touch the pot but no CC sent…
Thanks
Get rid of the int because this creates a new variable that is not the same as the global variable of the same name.
Also replace
with
if ( abs (analogValue-lastAnalogValue) > 2)
Also no need for this
Because this is already true when you get to this point.
Thanks for reply i tried without success.
But this is strange i also tried this
#include <MIDI.h>
 MIDI.sendControlChange(12, 10, 1);
and only clock is send, no CC
Well that is not what I asked you to do. However this code is based on what you posted last. I have tested it and it works.
#include <MIDI.h>
    MIDI.begin(1);
    MIDI.turnThruOff();
 //                    CC   value  channel
 delay(1000); // don't send too fast
OK thanks
This code doesn’t send CC i think my shield is not good that’s why i can try many codes and nothing works
It could be your lead as well.
What shield are you using?
I use this MIDI shield
with this arduino uno
I connect Tx, Rx, 5V and GND
Thanks a lot for your help
Do i have to buy another one?
What did you connect additionaly? When you plug the shield on the Arduino, all connections are done.
nothing only these four pins
Did you not directly plug it on the UNO? Why?
There was no plug that’s why i connected only 4
Is it right or i hate to connect everything?
i buied a new shield and everything is good thanks for your help
