Verify first that your joystick does give you a full range between 0 and 1023 and 512 in the middle, when idle
If so then try this code
int analogValue = analogRead(A0) - 512; // 0 at mid point
if ( abs(analogValue-lastAnalogValue) > 1) { // have we moved enough to avoid analog jitter?
if ( abs(analogValue) > 4) { // are we out of the central dead zone?
MIDI.sendPitchBend(8*analogValue, 1); // or -8 depending which way you want to go up and down
lastAnalogValue = analogValue;
Note that you can pass something between -8192 (maximum downwards bend) and 8191 (max upwards bend) and center value is 0. As we have a analogValue Between -512 and +511, multiplying by 8 just gives you half the range. You could multiply by 16 if you want
I was attempting to build something similar following the instruction in this blog post
However the results were not convincing.
If i'd like to print the raw values of the analog read and the resulting midi messagge on the serial monitor how should i do it?
I tried with this code but it does not works:
#include <MIDI.h>
MIDI_CREATE_DEFAULT_INSTANCE();
// Onboard led
const int ledPin = LED_BUILTIN;// the number of the LED pin
const int mididelay = 2;
int lastAnalogValue;
MIDI.begin (MIDI_CHANNEL_OMNI);
MIDI.sendPitchBend(16*analogValue, 1); // or -8 depending which way you want to go up and down
digitalWrite(ledPin, HIGH);
delay(mididelay);
digitalWrite(ledPin, LOW);
Serial.print("vx = ");
Serial.print(lastAnalogValue);
Serial.print("\t bend = ");
Serial.print(16*analogValue);
I tried by changing the baud rate in both the monitor and the sketch but i keep getting unreadable characters.
Sorry if my request is trivial, but I don't know how to code in C and how use IO from arduino.
I suspect MIDI is using the hardware serial port and setting it to 31250 baud.
If you want to log to a second serial port you'll need either an Arduino with
several serial ports, or to use one of the software serial librarys.
MIDI works by using 31250 baud on a serial port. Perhaps you meant to set it up
on a different port?
Sorry i was not clear. Indeed 31250 baud rate is necessary to work with midi,from what i read around.
What i meant to ask is having a way of reading the midi messages in the serial console, without necessarily having an active communication with a midi device.
So the idea would be to use a different baud rate just to read some out values while customizing the code.
The 31250 baud rate is a problem for reading serail monitor.
Also serial print function causes troubles with midi messages don't use it.
I use sometimes an LCD screen to read values
