Send MMS and Email using Arduino GSM Shield
Hello Friends,
I want to know how to send E-mail as well as MMS using Arduino GSM Shield. SIM900D supports both but I am not sure if there is any document which shows each step that need to given to send E-mail or MMS.
Is there anyone who had worked on such projects?
Regards,
Hi
A bit of google-fu has hopefully found some info you can use.
Firstly, if your shield does have the SIM900D chipset, then email appears to be a somewhat straightforward set of AT commands outlined here in the SIM900 Email AT Command Manual (PDF). In the introduction paragraph it confirms the SIM900D conforms to this operation. From a quick scan through, so long as you know your SMTP from your POP3 this should be helpful.
For MMS I think the answer is probably in sending an SMS in PDU mode (rather than text). There's an explanation of what's possible here (I didn't read all 17 parts, but it looks to be pretty thorough). And it appears many of the sites that talk about operation of the SIM900 based shields (like this one) can help you get an SMS started in PDU mode.
I've not done this, just hate seeing a 0-reply post...so hope something here can be of help to get you on the way, cheers ! Geoff
strykeroz: Hi
Hi strykeroz ,
Thanks a ton. You have done great job for me. Thanks again for sharing this useful documents.
Regards, Madhav
For Email, you can use www.smtp2go.com along with Wifly and Mifi from any provider. I guess that's not what you asked...
I am also trying to send MMS using the SIM900. Sending SMS and MMS are totally different from my experience. MMS requires that you upload something to the module and my current problem is that I can’t get the module to read what I’m putting on the UART. Perhaps I’m not putting data on the UART right, but yeah, I can’t get MMS to go. If you figure it out could you post it in this thread or contact me please? ted_pham08@yahoo.com
Thanks and good luck!
Ted
sbright33: For Email, you can use www.smtp2go.com along with Wifly and Mifi from any provider. I guess that's not what you asked...
Yeah, its something related to Desktop application.
HI have you successed on sending MMS / Email using Arduino?Please help me with the details
BARAKA: HI have you successed on sending MMS / Email using Arduino?Please help me with the details
Well not yet. But got some basic knowledge about basic parameters that might needed for sending MMS.
OK. Thanks for update Please let us keep in touch my email:barackludger@yahoo.com....There is this [http://www.geekonfire.com/wiki/index.php?title=GPRS_Shield%EF%BC%88SIM900%EF%BC%89_Firmware_Update] you should know,i am currently waiting for Arduino Uno with FT232 to make that Firmware upgrade.Hope you will understand what i mean when you open that link for SIM900 firmware upgrade
Has anyone had any success with this yet?
Any updates on how to send an Email message using a Sim900 GSM Shield?
Hello guys, have you succeeded in downloading jpg in uart and send it using gsm shield? i'm having trouble now regarding the CMMSDOWN. please help me.
As using the MMS feature of the SIM900 seems to be a problem to many (and certainly took me a few days to implement) I offer the following:
It may be necessary to update the SIM900 firmware to that which supports MMS. If so it won't be enough to simply update the firmware from the SimCom website. It specifically needs to be that which supports MMS; like "1137B03SIM900M64_ST_MMS"
Also, realize that the MMS AT commands are not included in the "AT Command Manual". MMS commands are included in the "SIM900 MSS AT Command Manual."
The following are the AT Commands that worked for me. I program in Basic using BASCOM. The results of that effort can be found at
http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewforum&f=8
Note the use of CHR (34) is how I deal with imbedded quotation marks.
Print "AT+CMMSINIT" Print "AT+CMMSCURL="; CHR(34); "mmsc.cingular.com"; CHR(34) Print "AT+CMMSCID=1" 'my connection is to AT&T in the US. They provide the MMS Gateway as '"wireless.cingular.com." For the SIM900 the gateway must be a specific 'IP address, Using an online IP and Domain checker I found that the address for '"wireless.cingular.com" is "066.209.11.32"
Print "AT+CMMSPROTO="; CHR(34); "066.209.11.32" ; ; CHR(34); ",80" Print "AT+SAPBR=3,1,"; Chr(34); "CONTYPE"; Chr(34); ","; Chr(34); "GPRS"; Chr(34) Print "AT+SAPBR=3,1,"; Chr(34); "APN"; Chr(34); ","; Chr(34); "wap.cingular"; Chr(34)
'add password and user ID here if required (not required for AT&T MMS)
Print "AT+SAPBR=1,1" Print "AT+SAPBR=2,1" Print "AT+CMMSEDIT=1" Print "AT+CMMSDOWN="; CHR(34); "TEXT"; CHR(34); ",6,5000" 'text of 6 bytes and Print"3280wa" 'send MMS message to Sim900 Print "AT+CMMSRECP="; CHR(34); phone ; CHR(34) 'add first recipient, Print "AT+CMMSRECP="; CHR(34); email ; CHR(34) 'add second recipient, Print "AT+CMMSVIEW" Print "AT+CMMSSEND" 'send MMS to AT&T Print "AT+CMMSEDIT=0" 'Exit edit mode and clear MMS buffer Print "CMMSTERM" 'Exit the MMS function
