slipstick:
Google “Arduino color organ”. That should give you some ideas. But sending audio to the Arduino wirelessly is not so easy. Arduino wireless solutions are designed for data not audio signals.
Steve
The problem with the light organs that I saw is that I don’t see most of the electronics for sale here, but I already have some saved here for reference so it’s always good to ask to have a vision to see if I missed something
the2ndtierney:
It is tricky for Arduino but easy on ESP32 (via the Arduino IDE). See this library for Bluetooth audio. The library has some very simple examples if you want to use I2S for audio output but if you want to just work with the raw data directly the code below will work on ESP32 (the I2S parts are not relevant). The function bt_data_cb can be used to change volume and output the data to an I2S DAC but you can change this to process the data however you want (process and send to LED strip).
// cricial audio bits taken from https://github.com/espressif/esp-idf/blob/master/examples/bluetooth/bluedroid/classic_bt/a2dp_sink/main/main.c
// bluetooth, config, discover and audio
#include “esp_bt_main.h”
#include “esp_bt_device.h”
#include “esp_gap_bt_api.h”
#include “esp_a2dp_api.h”
// the audio DAC and amp configuration.
#include “driver/i2s.h”
//globals
// the callback(processes bluetooth data).
// this is the most important function.
void bt_data_cb(const uint8_t data, uint32_t len){
// number of 16 bit samples
int n = len/2;
// point to a 16bit sample
int16_t data16=(int16_t*)data;
// create a variable (potentially processed) that we’ll pass via I2S
int16_t fy;
// Records number of bytes written via I2S
size_t i2s_bytes_write = 0;
for(int i=0;i<n;i++){
// put the current sample in fy
fy=*data16;
//making this value larger will decrease the volume(Very simple DSP!).
fy/=1;
// write data to I2S buffer
i2s_write(I2S_NUM_0, &fy, 2, &i2s_bytes_write, 10 );
//move to next memory address housing 16 bit data
data16++;
// i2s configuration
static const i2s_config_t i2s_config = {
.mode = static_cast<i2s_mode_t>(I2S_MODE_MASTER | I2S_MODE_TX),
.sample_rate = 44100,
.bits_per_sample = I2S_BITS_PER_SAMPLE_16BIT,
.channel_format = I2S_CHANNEL_FMT_RIGHT_LEFT,
.communication_format = static_cast<i2s_comm_format_t>(I2S_COMM_FORMAT_I2S|I2S_COMM_FORMAT_I2S_MSB),
.intr_alloc_flags = ESP_INTR_FLAG_LEVEL1, // default interrupt priority
.dma_buf_count = 8,
.dma_buf_len = 1000,
.use_apll = false,
.tx_desc_auto_clear = true
// i2s pinout
static const i2s_pin_config_t pin_config = {
.bck_io_num = 26,//26
.ws_io_num = 27,
.data_out_num = 25, //
.data_in_num = I2S_PIN_NO_CHANGE
// now configure i2s with constructed pinout and config
i2s_driver_install(I2S_NUM_0, &i2s_config, 0, NULL);
i2s_set_pin(I2S_NUM_0, &pin_config);
i2s_set_clk(I2S_NUM_0, 44100, I2S_BITS_PER_SAMPLE_16BIT, I2S_CHANNEL_STEREO);
i2s_set_sample_rates(I2S_NUM_0, 44100);
// set up bluetooth classic via bluedroid
btStart();
esp_bluedroid_init();
esp_bluedroid_enable();
// set up device name
const char *dev_name = “ESP_SPEAKER”;
esp_bt_dev_set_device_name(dev_name);
// initialize A2DP sink and set the data callback(A2DP is bluetooth audio)
esp_a2d_sink_register_data_callback(bt_data_cb);
esp_a2d_sink_init();
// set discoverable and connectable mode, wait to be connected
esp_bt_gap_set_scan_mode(ESP_BT_SCAN_MODE_CONNECTABLE_DISCOVERABLE);
Thank you very much this library should be exactly what I need, I will order this esp referred to test
