Send output only when input changes.
Hello, I am new to Arduino and this is just a learning project I have been working on.
I have a DMX shield (digital stage lighting controller) using the Conceptinetics library. The shield is controlling a fiber optics driver that uses 4 DMX channels and I have 4 linear potentiometers sending input to the Arduino.
The problem is, the code constantly sends DMX values on all 4 channels, every time the loop repeats. I need to find a way to send a DMX value only when the input for that channel has changed. So, I need to be able to send output for channel 1 only when the channel 1 pot is moving and have no output sent on the other 3 channels. i.e. channel 1 pot moves, channel 1 sends new DMX output.
I have tried a few things that didn't work out. Can someone show me an example that may work or point me the right direction. Thank you.
#include <Conceptinetics.h>
#define DMX_MASTER_CHANNELS   100
// Pin number to change read or write mode on the shield
#define RXEN_PIN                2
// Configure a DMX master controller, the master controller
// will use the RXEN_PIN to control its write operation on the bus
DMX_Master        dmx_master ( DMX_MASTER_CHANNELS, RXEN_PIN );
int color = 1; // DMX chan 1, 0 and 255 = no color, 32 = purple, 64 = yellow, 96 = teal,
               // 128 = orange, 160 = blue, 192 = pink, 224 = green
int cycle = 2; // DMX chan 2, 0 = off, forward 1 = slow, 127 = fast, 128 to 255?
int fade = 3; // DMX chan 3, 0 = full, 127 = off, 255 = full
int strobe = 4; // DMX chan 4, 0 = off, 1 = slow, 255 = fast
int sensorPin0 = A0;
int sensorPin1 = A1;
int sensorPin2 = A2;
int sensorPin3 = A3;
int dmxval0 = 0;
int dmxval1 = 1;
int dmxval2 = 2;
int dmxval3 = 3;
   dmx_master.enable ();
 fibercolor();
 fibercycle();
 fiberfade();
 fiberstrobe();
void fibercolor()
  dmxval0 = analogRead(sensorPin0);
  dmxval0 = dmxval0 / 4;
  dmx_master.setChannelValue ( color, dmxval0 );
void fibercycle()
  dmxval1 = analogRead(sensorPin1);
  dmxval1 = dmxval1 / 4;
  dmx_master.setChannelValue ( cycle, dmxval1 );
void fiberfade()
  dmxval2 = analogRead(sensorPin2);
  dmxval2 = dmxval2 / 4;
  dmx_master.setChannelValue ( fade, dmxval2 );
void fiberstrobe()
  dmxval3 = analogRead(sensorPin3);
  dmxval3 = dmxval3 / 4;
  dmx_master.setChannelValue ( strobe, dmxval3 );
When you are tempted to suffix variable names with letters or numbers, it is time to learn about arrays.
Things like this:
probably change all of the time. I hope that you have a good definition for "pot is moving".
The most important question to answer is: What is YOUR definition of "pot is moving".
In fact, there are four nearly identical functions and I don't understand the need, although it does look pretty.
What you are asking is easy to do with an Arduino but I don't want to write all of the code, especially if it has to be done without arrays.
And never mind. I just figured out, by trying this code with a LED light, that loose connections on the DMX shield are causing phantom signals. I sometimes get flashing of all three colors when the corresponding pots are at 0 but wiggling the wires fixes it... until they get moved again.
@Delta_G, saving a comparing the last setting to the current one is what I was attempting and thinking it wasn't working. I do now believe it is working when all the connections are secure.
@vaj4088, I'll read about arrays and see if I can learn something new.
Thanks for the help.
vaj4088:
And when you have clusters of different variable names all suffixed with litters or numbers, like this
int dmxval0 = 0;
int dmxval1 = 1;
int dmxval2 = 2;
int dmxval3 = 3;
It's time to learn about structs and classes.
struct DmxFaderFollower {
  byte sensorPin;
  byte dmxChannel;
  byte currentValue = 0;
  DmxFaderFollower(byte attachSensor, byte attachChannel) :
    sensorPin(attachSensor),
    dmxChannel(attachChannel)
  void setup() {}
    byte newValue = analogRead(sensorPin) / 4;
    if(newValue != currentValue) {
      dmx_master.setChannelValue (newValue, dmxChannel);
      currentValue = newValue;
DmxFaderFollower
 color(A0, 0),
 cycle(A1, 1),
 fade(A2, 2),
 strobe(A3, 3);
  color.setup();
  cycle.setup();
  fade.setup();
  strobe.setup();
  color.loop();
  cycle.loop();
  fade.loop();
  strobe.loop();
