I am working on a project where i have two push buttons. One sends a "0" and the other sends a "1".
I have the program working to where i can see that the buttons are functioning on the COM Serial Monitor when plugged in via USB.
What i am wanting to do is have it send a signal as a PS2 format over a RJ12 6 wire connection.
How should i go about transmitting this with the data and the clock?
Do i need to include the ps2dev.h in the code?
I am not using a keyboard just wanting to send data over the RJ12 connection as the Arduino was a keyboard. I am using a Pro Micro. So far i have the ground and the power hooked up. Yellow to the RAW and the Green to the ground.
I have my code so far attached.
Thanks,
Keyboard01.ino (872 Bytes)
Don't attach the code. Just post it inside code tags.
Here is his code:
#include "Keyboard.h"
const int button1Pin = 3; // pushbutton 1 pin
const int button2Pin = 5; // pushbutton 2 pin
// open the serial port:
// initialize control over the keyboard:
// Keyboard.begin();
pinMode(button1Pin, INPUT);
pinMode(button2Pin, INPUT);
//Keyboard.begin();
int button1State, button2State; // variables to hold the pushbutton states
button1State = digitalRead(button1Pin);
button2State = digitalRead(button2Pin);
if(button1State == HIGH)
Serial.println('0');
//Keyboard.begin();
//Keyboard.write(48);
// Keyboard.end();
return;
if(button2State == HIGH)
Serial.println('1');
//Keyboard.begin();
// Keyboard.write(49);
//Keyboard.end();
return;
Thanks for the link. I am not looking at hooking up a PS2 keyboard to the device.
I am wanting the ardunio to act as a keyboard that has only two mechanical buttons.
I then want to send the data out as if it were a key board hooked to a PC with the 6 wire rj12 cable.
The RJ12 will supply the power to the ardunio and the mirco USB will not be used in production.
mcguffeyd1:
Yes, but the link gives you an understanding of how to communicate using PS2 protocols with an Arduino.
