i m so sorry, i was writing from a pc with no arduino installed, i hope this is fine now
Ps: to avoid mistakes i didn't delete useless strings
[code]
#include <MIDI.h>
#include "Controller.h"
MIDI_CREATE_DEFAULT_INSTANCE();
//***SET THE NUMBER OF CONTROLS USED**************************
//---How many buttons are connected directly to pins?---------
byte NUMBER_BUTTONS = 8;
//---How many potentiometers are connected directly to pins?--
byte NUMBER_POTS = 0;
//---How many buttons are connected to a multiplexer?---------
byte NUMBER_MUX_BUTTONS = 0;
//---How many potentiometers are connected to a multiplexer?--
byte NUMBER_MUX_POTS = 0;
Pot *POTS[] {};
//***DEFINE DIRECTLY CONNECTED BUTTONS*******************************
//Button (Pin Number, Command, Note Number, Channel, Debounce Time)
//** Command parameter 0=NOTE 1=CC 2=Toggle CC **
Button BU1(2, 1, 0, 1, 5 );
Button BU2(3, 1, 1, 1, 5 );
Button BU3(4, 1, 2, 1, 5 );
Button BU4(5, 1, 3, 1, 5 );
Button BU5(6, 1, 4, 1, 5 );
Button BU6(7, 1, 5, 1, 5 );
Button BU7(8, 1, 6, 1, 5 );
Button BU8(9, 1, 7, 1, 5 );
//Add buttons used to array below like this-> Button *BUTTONS[] {&BU1, &BU2, &BU3, &BU4, &BU5, &BU6, &BU7, &BU8};
Button *MUXBUTTONS[] {};
Pot *MUXPOTS[] {};
MIDI.begin(MIDI_CHANNEL_OFF);
if (NUMBER_BUTTONS != 0) updateButtons();
if (NUMBER_POTS != 0) updatePots();
if (NUMBER_MUX_BUTTONS != 0) updateMuxButtons();
if (NUMBER_MUX_POTS != 0) updateMuxPots();
void updateButtons() {
// Cycle through Button array
for (int i = 0; i < NUMBER_BUTTONS; i = i + 1) {
byte message = BUTTONS[i]->getValue();
// Button is pressed
if (message == 0) {
switch (BUTTONS[i]->Bcommand) {
case 0: //Note
MIDI.sendNoteOn(BUTTONS[i]->Bvalue, 127, BUTTONS[i]->Bchannel);
case 1: //CC
MIDI.sendProgramChange(BUTTONS[i]->Bvalue, BUTTONS[i]->Bchannel); // RIGA DI ERRORE PER LEO
case 2: //Toggle
if (BUTTONS[i]->Btoggle == 0) {
MIDI.sendControlChange(BUTTONS[i]->Bvalue, 127, BUTTONS[i]->Bchannel);
BUTTONS[i]->Btoggle = 1;
else if (BUTTONS[i]->Btoggle == 1) {
MIDI.sendControlChange(BUTTONS[i]->Bvalue, 0, BUTTONS[i]->Bchannel);
BUTTONS[i]->Btoggle = 0;
// Button is not pressed
if (message == 1) {
case 0:
MIDI.sendNoteOff(BUTTONS[i]->Bvalue, 0, BUTTONS[i]->Bchannel);
case 1:
void updateMuxButtons() {
// Cycle through Mux Button array
for (int i = 0; i < NUMBER_MUX_BUTTONS; i = i + 1) {
MUXBUTTONS[i]->muxUpdate();
byte message = MUXBUTTONS[i]->getValue();
if (message == 0) {
switch (MUXBUTTONS[i]->Bcommand) {
case 0: //Note
MIDI.sendNoteOn(MUXBUTTONS[i]->Bvalue, 127, MUXBUTTONS[i]->Bchannel);
case 1: //CC
MIDI.sendControlChange(MUXBUTTONS[i]->Bvalue, 127, MUXBUTTONS[i]->Bchannel);
case 2: //Toggle
if (MUXBUTTONS[i]->Btoggle == 0) {
MUXBUTTONS[i]->Btoggle = 1;
else if (MUXBUTTONS[i]->Btoggle == 1) {
MIDI.sendControlChange(MUXBUTTONS[i]->Bvalue, 0, MUXBUTTONS[i]->Bchannel);
MUXBUTTONS[i]->Btoggle = 0;
if (message == 1) {
case 0:
MIDI.sendNoteOff(MUXBUTTONS[i]->Bvalue, 0, MUXBUTTONS[i]->Bchannel);
case 1:
void updatePots() {
for (int i = 0; i < NUMBER_POTS; i = i + 1) {
byte potmessage = POTS[i]->getValue();
if (potmessage != 255) MIDI.sendControlChange(POTS[i]->Pcontrol, potmessage, POTS[i]->Pchannel);
void updateMuxPots() {
for (int i = 0; i < NUMBER_MUX_POTS; i = i + 1) {
MUXPOTS[i]->muxUpdate();
byte potmessage = MUXPOTS[i]->getValue();
if (potmessage != 255) MIDI.sendControlChange(MUXPOTS[i]->Pcontrol, potmessage, MUXPOTS[i]->Pchannel);
[/code]
