Send/Read more variables using I2C (SOLVED!!!)
Yes, is that I want. But in the code above, you send from a MASTER to a SLAVE. What I want is to send from a SLAVE to a MASTER. I want to send to the master the state of some pins of the slave.
I hope that you did understood me. :slight_smile: If not, please tell me where I'm not clear to intent to explain it because I'm stuck in this problem and I need a solution quite quickly.
Thanks a lot! :slight_smile:
lol you can call the Drunk1 and Drunk2 for all tha it matters ,,, Just put the code the the one your reading data from as master , and the other as as slave,, but Calling the units what ever you want has nothign to do with it...... its all about the code of who is doing what.
But if you need to read all about I2C Gammon Forum : Electronics : Microprocessors : Buttons, I2C, interrupts and port-expanders to get enough info , here is the link and since ive already done this Road Pins Are there ever enough - #12 by system - IDE 1.x - Arduino Forum Good luck
But in my case, the master needs to "write" and to "read" too. It reads from the slave the state of some pins and in function of the state of this pins it sends back to the slave what other pins needs to drive up!
This is why I can't swap the code. I'll be in the same situation.
Thank you for everything!
PS If you have any idea, just shoot and I'll try it because I'm out of any idea and I don't find anything that could help me.
hm - this one may require some more thought, or some one that has ran that required setup , im only controlling a solar array a lcd and a Relay bank VIA a Ir remote, with two UNOs ,sounds like your trying to do more than that :slight_smile:
:slight_smile:
I want to build a kind of PLC to control a industrial machine. In some cases I'll use more than 3 Atmega328.
I hope that somebody who knows more about programming an I2C protocol will see my post and have the kindness to explain me how should I do.
Thank you very much Woody! :slight_smile:
Look what I've found:
Warning - because of the way the Wire library is written, the requestEvent handler can only (successfully) do a single send. The reason is that each attempt to send a reply resets the internal buffer back to the start. Thus in your requestEvent, if you need to send multiple bytes, you should assemble them into a temporary buffer, and then send that buffer using a single Wire.send. For example:
void requestEvent()
byte buf [2];
buf [ 0 ] = 42;
buf [ 1 ] = 55;
Wire.send(buf, sizeof buf); // send 2-byte response
For UNO Wire.send became Wire.write.
I've tried the example given and didn't work! So... it's impossible (I think)!
SOLVED!!!
So, to transmit more than 1 value via I2C, I'm doing like this:
I give to all the chips an address (Wire.begin(address)); when I want to send something, I use Wire.beginTransmission(address). I build a "void receiveEvent(int howMany)" in each of the chips. Now the question I had was "how could the receiver knows who is sending data". It's simple: every time when I send something, first I send a "address". Than I use the "if" function (in the receiver) to recognize the sender.
That's all! It functions just GREAT!
If someone else has an alternate idea, post it. Could be better than mine.
Hi. Could you post and example about how you did?
