I am using Arduino mega for this project. I have two sensors data (streams of bytes) but now I want following things:
to send these two sensors data into a single packet, in which these two sensors data are gathered. I mean I want to have a packet in which I have oxygen, heart rate and pedometer values.
I want to send acknowledge bit at the end which confirms that all data is received and send new data now.
I have to add device name in packet for all devices.
I have to set timer to upload data only when user want.
Can anyone tell me how to do it. Code for both sensors are given below. I have already try a lot of ways but all in vain. I am not expert of Arduino please help me. I will be very thankful for your suggestions and time.
For sensor 1
#include <Wire.h>
#include "MAX30105.h"
#include "spo2_algorithm.h"
MAX30105 particleSensor;
#define MAX_BRIGHTNESS 255
#if defined(__AVR_ATmega328P__) || defined(__AVR_ATmega168__)
//Arduino Uno doesn't have enough SRAM to store 100 samples of IR led data and red led data in 32-bit format
//To solve this problem, 16-bit MSB of the sampled data will be truncated. Samples become 16-bit data.
uint16_t irBuffer[100]; //infrared LED sensor data
uint16_t redBuffer[100]; //red LED sensor data
#else
uint32_t irBuffer[100]; //infrared LED sensor data
uint32_t redBuffer[100]; //red LED sensor data
#endif
int32_t bufferLength; //data length
int32_t spo2; //SPO2 value
int8_t validSPO2; //indicator to show if the SPO2 calculation is valid
int32_t heartRate; //heart rate value
int8_t validHeartRate; //indicator to show if the heart rate calculation is valid
uint16_t checkSum = 0;
byte pulseLED = 11; //Must be on PWM pin
byte readLED = 13; //Blinks with each data read
byte ledBrightness = 60; //Options: 0=Off to 255=50mA
byte sampleAverage = 4; //Options: 1, 2, 4, 8, 16, 32
byte ledMode = 2; //Options: 1 = Red only, 2 = Red + IR, 3 = Red + IR + Green
byte sampleRate = 100; //Options: 50, 100, 200, 400, 800, 1000, 1600, 3200
int pulseWidth = 411; //Options: 69, 118, 215, 411
int adcRange = 4096; //Options: 2048, 4096, 8192, 16384
wait_for_Max30102();
start_signal();
if (!particleSensor.begin(Wire, I2C_SPEED_FAST)) //Use default I2C port, 400kHz speed
Serial.println(F("MAX30105 was not found. Please check wiring/power."));
while (1);
Serial.println(F("Attach sensor to finger with rubber band. Press any key to start conversion"));
//while (Serial.available() == 0) ; //wait until user presses a key
Serial.read();
particleSensor.setup(ledBrightness, sampleAverage, ledMode, sampleRate, pulseWidth, adcRange); //Configure sensor with these settings
bufferLength = 100; //buffer length of 100 stores 4 seconds of samples running at 25sps
//read the first 100 samples, and determine the signal range
for (byte i = 0 ; i < bufferLength ; i++)
while (particleSensor.available() == false) //do we have new data?
particleSensor.check(); //Check the sensor for new data
redBuffer[i] = particleSensor.getRed();
irBuffer[i] = particleSensor.getIR();
particleSensor.nextSample(); //We're finished with this sample so move to next sample
/*Serial.print(F("red="));
Serial.print("\t");
Serial.print(redBuffer[i], BIN);
Serial.print("\t");
Serial.print(redBuffer[i], DEC);
Serial.print("\n");
Serial.print(F(", ir="));
Serial.print("\t");
Serial.println(irBuffer[i], BIN);
Serial.print("\t");
Serial.print(irBuffer[i], DEC);
Serial.print("\n");*/
//calculate heart rate and SpO2 after first 100 samples (first 4 seconds of samples)
maxim_heart_rate_and_oxygen_saturation(irBuffer, bufferLength, redBuffer, &spo2, &validSPO2, &heartRate, &validHeartRate);
//Continuously taking samples from MAX30102. Heart rate and SpO2 are calculated every 1 second
while (1)
//dumping the first 25 sets of samples in the memory and shift the last 75 sets of samples to the top
for (byte i = 25; i < 100; i++)
redBuffer[i - 25] = redBuffer[i];
irBuffer[i - 25] = irBuffer[i];
//take 25 sets of samples before calculating the heart rate.
for (byte i = 75; i < 100; i++)
digitalWrite(readLED, !digitalRead(readLED)); //Blink onboard LED with every data read
checkSum = redBuffer[i] + irBuffer[i] + heartRate + validHeartRate + spo2 + validSPO2;
//send samples and calculation result to terminal program through UART
Serial.print(F("RED: "));
Serial.print("\t");
Serial.print("\t");
Serial.println("");
Serial.print(F("IR: "));
Serial.print("\t");
Serial.print(irBuffer[i], BIN);
Serial.print("\t");
Serial.println("");
Serial.print(F("HR: "));
Serial.print("\t");
Serial.print(heartRate, BIN);
Serial.print("\t");
Serial.print("\t");
Serial.print(heartRate, DEC);
//Serial.println("\t");
//Serial.print("(HRvalid = ");
//Serial.print("\t");
//Serial.print(validHeartRate, BIN);
//Serial.print(validHeartRate, DEC);
//Serial.print((" )"));
Serial.println("");
Serial.print(F("SPO2: "));
Serial.print("\t");
Serial.print(spo2, BIN);
Serial.print("\t");
Serial.print("\t");
Serial.print(spo2, DEC);
//Serial.print("(SPO2Valid = ");
//Serial.println(validSPO2, BIN);
//Serial.println(validSPO2, DEC);
//Serial.print(" )");
Serial.print("\n");
Serial.println("");
Serial.print(F("Checksum Byte: "));
Serial.print("\t");
Serial.print(checkSum, BIN);
Serial.print("\t");
if((byte)checkSum == (byte)(redBuffer[i] + irBuffer[i] + heartRate + validHeartRate + spo2 + validSPO2)){Serial.print("(CHECKSUM_OK)");}
else {Serial.print("(CHECKSUM_ERROR)");}
Serial.println("\n");
Serial.println("");
Serial.println("");
Serial.println("");
//After gathering 25 new samples recalculate HR and SP02
Serial.end();
void wait_for_Max30102()
delay(2000);
void start_signal(){
pinMode(readLED, OUTPUT);
pinMode(pulseLED, OUTPUT);
digitalWrite(pulseLED, LOW);
digitalWrite(readLED, LOW);
delay(18);
digitalWrite(pulseLED, HIGH);
digitalWrite(readLED, HIGH);
pinMode(pulseLED, INPUT);
pinMode(readLED, INPUT);
For sensor 2
#include <Wire.h>
#define DEVICE (0x53) //ADXL345 device address
#define TO_READ (6) //num of bytes we are going to read each time (two bytes for each axis)
#define offsetX -10.5 // OFFSET values
#define offsetY -2.5
#define offsetZ -4.5
#define gainX 257.5 // GAIN factors
#define gainY 254.5
#define gainZ 248.5
byte buff[TO_READ] ; //6 bytes buffer for saving data read from the device
char str[512]; //string buffer to transform data before sending it to the serial port
int x,y,z, X;
int xavg, yavg,zavg, steps=0, flag=0;
int xval[15]={0}, yval[15]={0}, zval[15]={0};
int threshhold = 60.0;
void setup(){}
for(unsigned int x = 0; x < 5; x++)
{ clv(); }
Serial.end();
writeTo(DEVICE, 0x2D, 0);
writeTo(DEVICE, 0x2D, 16);
writeTo(DEVICE, 0x2D, 8);
void clv(){
Wire.begin(); // join i2c bus (address optional for master)
Serial.begin(9600); // start serial for output
start_signal();
//Turning on the ADXL345
int regAddress = 0x32; //first axis-acceleration-data register on the ADXL345
readFrom(DEVICE, regAddress, TO_READ, buff); //read the acceleration data from the ADXL345
//each axis reading comes in 10 bit resolution, ie 2 bytes. Least Significat Byte first!!
//thus we are converting both bytes in to one int
x = (((int)buff[1]) << 8) | buff[0];
y = (((int)buff[3])<< 8) | buff[2];
z = (((int)buff[5]) << 8) | buff[4];
//we send the x y z values as a string to the serial port
//sprintf(str, "%d %d %d", x, y, z);
//Serial.print(str);
//Serial.print(10, byte());
Serial.print("X = ");
Serial.println(x);
Serial.print("Y = ");
Serial.println(y);
Serial.print("Z = ");
Serial.println(z);
//write steps
X = ArduinoPedometerSteps();
Serial.print("steps = ");
Serial.println(X);
Serial.println(" ");
//It appears that delay is needed in order not to clog the port
Serial.print(F("X: "));
Serial.print("\t");
Serial.print(x, BIN);
Serial.print("\t");
Serial.print(x, DEC);
Serial.print("\n");
Serial.print(F("Y: "));
Serial.print("\t");
Serial.print(y, BIN);
Serial.print("\t");
Serial.print(y, DEC);
Serial.print("\n");
Serial.print(F("Z: "));
Serial.print("\t");
Serial.print(z, BIN);
Serial.print("\t");
Serial.print(z, DEC);
Serial.print("\n");
Serial.print(F("steps: "));
Serial.print("\t");
Serial.print(X, BIN);
Serial.print("\t");
Serial.print(X, DEC);
checkSum = x + y + z + X;
Serial.print("\t");
Serial.print("\t");
if((byte)checkSum == (byte)(x + y + z + X)){Serial.print("(CHECKSUM_OK)");}
Serial.println("");
Serial.println("");
Serial.println("");
delay(150);
//---------------- Functions
//Writes val to address register on device
void writeTo(int device, byte address, byte val) {
Wire.beginTransmission(device); //start transmission to device
Wire.write(address); // send register address
Wire.write(val); // send value to write
Wire.endTransmission(); //end transmission
//reads num bytes starting from address register on device in to buff array
void readFrom(int device, byte address, int num, byte buff[]) {
Wire.write(address); //sends address to read from
Wire.requestFrom(device, num); // request 6 bytes from device
int i = 0;
while(Wire.available()) //device may send less than requested (abnormal)
buff[i] = Wire.read(); // receive a byte
i++;
//Get pedometer.
int ArduinoPedometerSteps(){
int acc=0;
int totvect[15]={0};
int totave[15]={0};
int xaccl[15]={0};
int yaccl[15]={0};
int zaccl[15]={0};
for (int i=0;i<15;i++)
xaccl[i]= x;
delay(1);
yaccl[i]= y;
delay(1);
zaccl[i]= z;
delay(1);
totvect[i] = sqrt(((xaccl[i]-xavg)* (xaccl[i]-xavg))+ ((yaccl[i] - yavg)*(yaccl[i] - yavg)) + ((zval[i] - zavg)*(zval[i] - zavg)));
totave[i] = (totvect[i] + totvect[i-1]) / 2 ;
//Serial.print("Total Average = ");
//Serial.println(totave[i] );
//delay(50);
//cal steps
if (totave[i]>threshhold && flag==0)
steps=steps+1;
flag=1;
else if (totave[i] > threshhold && flag==1)
//do nothing
if (totave[i] <threshhold && flag==1)
flag=0;
// Serial.print("steps=");
// Serial.println(steps);
return(steps);
delay(100);
