I have this project where I am supposed to be able control a LED light connected to Arduino via remote server. The script, which I can reach to control LED is hosted in host.server.com/myArduinoControl.php (not served by arduino) and the arduino is connected to the internet via ethernet shield somewhere in a different location. Is it possible to send a command to arduino via http from my PHP script? What I have found in the forum is in most cases page served by arduino itself.
The action that happens when a submit button on a form is selected does not have to be a script on the same server. It can be a script on a different server (the Arduino as server). Post your PHP script as it is today.
#include <UIPEthernet.h>
EthernetClient client;
EthernetServer server = EthernetServer(80);
char server[] = "192.168.0.3";
#define LED 2
int status, ledValue = 0;
String led, myStr;
boolean reading = false;
pinMode(LED, OUTPUT);
connectToInternet();
server.begin();
void connectToInternet() {
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
if (Ethernet.begin(mac) == 0) {
for(;;){
Serial.println(Ethernet.localIP());
void loop(){
checkForClient();
digitalWrite(LED, ledValue);
Sending some data to remote server in constant intervals
void checkForClient(){
if (client) {
boolean currentLineIsBlank = true;
boolean sentHeader = false;
myStr = "";
while (client.connected()) {
if (client.available()) {
char c = client.read();
if(reading && c == ' ')
reading = false;
if(c == '?')
reading = true;
if(reading){
if (c!='?') {
myStr += c;
if (c == '\n' && currentLineIsBlank)
if (c == '\n') {
else if (c != '\r') {
currentLineIsBlank = false;
parseReq(myStr);
client.stop();
void parseReq(String str) {
int startIndex = str.indexOf("led");
int endIndex = str.indexOf("e");
String led = str.substring(startIndex + 2, endIndex - 1);
char temp[4];
led.toCharArray(temp, sizeof(temp));
ledValue = atoi(temp);
I'm sending some data to remote server from arduino as well. How can I make the arduino receive the request of turning led on/off and send the data without blocking each of the action?
I can't see the relationship between this statement and
When you get it straight in your mind what you are trying to do, feel free to post again. Perhaps with a block diagram showing the servers, clients, scripts, etc.
I don't know about PHP, but pot your arduino URL in the hosted web page and send a GET request to the arduino something like below. The below uses no-ip.com for dynamic DNS with your arduino server operating behind your router on port 84.
